The alternator in your car is one of the easiest fixes you can do. First, remove the NEGATIVE (-) battery cable.
You must relieve the tension on the serpentine belt by loostening the retaining bolt, then remove the wiring harness plug from the back of the alternator, then remove the two retaining bolts from the alternator. Reverse the procedure to install the new alternator, making sure that belt tension is adequate. Replace the netgative battery cable last, and test.
If the serpentine belt is loose, replace the belt.
SOURCE: I cant get my 1994
i had the same problem. bought new key $30 cash, still didnt crank. I had a friend that works at a radio store bypass the theft system and i bought a new starter. havent had problems since.
SOURCE: need diagram of 1994 Accord sedan, ingition. Need
go to advance auto.com. they pull up what you need and show you the part
