Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
I am assuming this is a gas stove. You probably need a new flint in the igniter. Simple problem. Check your local hardware store for flint, and refer to your manufacturer's manual for how to install it. If it's not there, a quick call to a service technician should answer the problem. hope this has been helpful.
You said, It was working fine last night but when you woke up this morning the
display has 3 vertical lines and none of the electronic touch pads
work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time. This may reset the system. Let me know how it works.
Waiting for your answer. Huuum
Please remember to leave a rating. Hopefully it will be a solved! Let me know
