Cars & Trucks Logo
A
Anonymous Posted on May 10, 2015
What would cause my front dash light and my tail lights go out on a 98 Chevy Tahoe? It keeps blowing fuse after fuse. I have put in about 5 of them back to back and they keep blowing. Help
Mark Schmit
Level 3:
  • Cars & Trucks Master 1,915 Answers
  • Posted on May 10, 2015
Mark Schmit
Level 3:
Answers
1915
Questions
0
Helped
753260
Points
7967
If the fuses keep blowing it means you have a short somewhere in your wiring harness. These can sometimes be a pain to track down. I would check the wiring in the rear closely first. If you have ever had a trailer hitch and wiring installed check that as installers sometimes screw things up.
5 Related Answers
dj_ricko_198
ricky horwood
  • 128 Answers
  • Posted on Dec 27, 2008
SOURCE: 2003 dodge durango #4 fuse keeps blowing,
OK there is a short in your car
take all the light bulbs out of the light that trigger the problem this break the current place one bulb in at a time checking that the fuse has not blown this will pin point where the problem is
once you find the problem you can replace the socket as it may have started to corrode check for water
once you replace the socket you should not have a problem
if you do let me know
dj_ricko_1988 at hot mail dot com
Anonymous
  • 1861 Answers
  • Posted on Dec 31, 2008
SOURCE: T100 tail lights & dash light keep blowing fuses
If this vehicle has a trailer harness, that could be the problem; it could be shorted out. Additionally, if there is no trailer harness, look under the truck bed at the rear, look for a grey wiring connector that wires come out of, and run to the taillamps. I have observed corrrosion in this connector, which will result in a short circuit. You may find it necessary to cut the connector out and resplice the wires back together (eliminate the connector), if severe corrosion is indeed present.
Anonymous
  • 66 Answers
  • Posted on Jan 08, 2009
SOURCE: Tail lights and dash lights not working, keep blowing fuse.
you have a wire or a light socket grounding out ck were your lights go into the sockets has the car been wrecked any were near the lights if it has thats were you start if not start with your light sockets
Anonymous
  • Posted on Feb 11, 2009
SOURCE: 2001 buick regal *fuse problem*
i had one do about the same thing it also affected the headlights / dash and running lights what was found was broken wires by the passenger side trunk hinge the wires are in a flexable wire covering that runs from fender by the hinge up to the tail light lisc plate light wires were broken in there prob. from wear and tear
Anonymous
  • 4 Answers
  • Posted on Mar 29, 2009
SOURCE: tail lights dont work need
change bulbs check fuse
1helpful
Where is the tail light fuse?
The tail light fuse is under the rear seat on the drivers side.
My dashlight an taillight fuse keep blowing on my 99 chevy Tahoe what could be the problem piease help me
look for a bad bulb in tail lights or shorted wire in rear , if you have trailer lights wired in to rear for towing look for shorted wires , no idea on dash lights
I have a 98 chevy tahoe. The #9 fuse keeps blowing.
Try disconnecting one feed wire at a time to see which circuit is shorted to the body/frame of your Tahoe. If you disconnect the trailer lights first and the fuse still works, look for the short circuit in this wiring. Auto electrical problems take time and patience to try everything, but one step at a time.
Tail lights in 03 suzuki grand vitara not working keeps blowing fuse
If the fuse is blowing out it means you have a short cirtuit.possible causes the Light socket, pedal sensor or somewhere along the wiring harness Aires might na chewed you and touching each other
Brake lights work but tail lights won't work with front lights which are needed at night on 2000 Chevy Malibu! When inspected, everything was fine until inspector changed my left tail light. Now tail...
The Tail lights and Instrument lights are usually on the same circuit so both will go out if the fuse for the circuit blows. Check for a blown fuse for this circuit and replace if out. If fuse continues to fail, check the tail light or side globes for a faulty globe and replace if necessary. Also check for any chafed wires that could be shorting to the body causing the fuse to blow.
7helpful
2answers
Tail light fuse keeps blowing. I have traced the wiring back to the tail lights and it all seems fine. I have taken out the turn signal lights and the light switch, put in to the first position for parking...
Are the bulbs out of the sockets and the fuse blows?
Take bulbs out and check again
Place one back at a time if fuse was OK with bulbs out to locate bad bulb.
Otherwise.......
Do this........if still needed with bulbs out and fuse blowing.
Put a circuit breaker in to replace the fuse of the same amperage.
It will trip off then back on.
Use a standard cheap magnetic compass........place along lighting wiring........the wire with current will cause the needle to jump as circuit breaker trips on and off.
Follow path of current to problem.....the compass will stop moving once past the shorted /grounded wire/connection.
2answers
99 chevy tahoe keeps blowing tail light
check for short in tailights. or this happend on my tahoe but it was the factory trailer wires that had a short under the rear of the truck.
Electrical problem
Check your trailer plugin wires at back of veh.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
