-   trying to get to the filter on my Whirlpool Imperial SuperScour dishwasher. Trying to get ther by removing the spray arm end removing the top plastic cover... but it is held in by riviets.... Do I drill those out? then how do I put it back together? -   don-mgmt4
Nov 25, 2007
-   THE TOP ARM IS JUST NOT TURNING DISHES ON TOP STIL DIRTY
MODELADP 952-   Guest
It looks like there is not enough water pressure to spin the spray arms. Loss of pressure may be due to various things, like damaged seal, cracked tubes, clogged filters, screens etc. I suggest you take a look at the technician repair sheet that should be stored inside the front panel at the bottom of the door. Remove that panel under the door with screw driver. Inside, attached to the panel, you should find a troubleshooting guide and solution for technician. But it is easy to follow. Look at the section under "poor wash" and follow its recommendation. I had exact same problem - not enough water pressure. In my case, the chopper screen was clogged and the chopper assemply was broken. I followed the repair instruction above to remove the chopper assembly, cleaned the chopper screen and the washer now is as good as new. I will need to replace the chopper when the part arrives. Good Luck /Dara
sounds as if it is trying to empty...but already empty. Tried resetting program but just the same...
(More)
sounds as if it is trying to empty...but already empty. Tried resetting program but just the same when restart
My dishes never come out clean. They actually look worse after the dishwasher.I rinse my items too...
(More)
My dishes never come out clean. They actually look worse after the dishwasher.I rinse my items too before i put them in. The glasses and silverware look especially horrible. My rinse aid container is full. I used to always use cascade soap, i have tried electrosol and both brands in the power tabs with the rinse aid built in too.
I came into my kitchen today and found lots of water and soap all over the floor. I cleaned the...
(More)
I came into my kitchen today and found lots of water and soap all over the floor. I cleaned the filter which was mildly clogged . When i run it to check it now i find that the lower washer arms are not moving and the water appears dirty.
