Question about Onkyo TX-8222 Receiver
Graphic equalizer I have connected a graphic equalizer to my Onkyo TX-8222. The visual indicators on the equalizer work but there is no change in the sound when adjusting the equalizer. WhY?
    Brigadier General:
  • 8,546 Answers
In general all equalizers, being designed to be in a Tape Monitor loop, have the option to Equalize either the Source or the Tape or nothing. Check for that control and toggle it. My old ADC SS-525X has pushbuttons whose settings (Tape/Source) are not easily determined. I always have to play around with it to know which is selected.
I'm betting your EQ is processing the program that would head out to an attached tape deck.
Posted on May 18, 2009
I plug in the receiver and nothing happens; no light indicaters, no sound
Some commonlpace questions, ok, you don't need an expert for that:
Did you try another electric outlet?
Did you check plug, cable and connections to your receiver?
Did you try pressing on - off several times?
Sep 09, 2015 | Onkyo TX-8222 Receiver
How to hook up teac eqa-10mk2 to receiver onkyo tx-8222
Hi Daniel you can connect your Eq to the Tape2 input/output, if you need further assistance please give our Product Support Team a call at 800-229-1687 they are available 24/7, Thanks, JT
Apr 25, 2015 | Onkyo Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Graphic equalizer how to connect for my turntable to work with it
There should be the connections from the turntable connected to the input of the equalizer then the output of the equalizer to an amp
Some turntables require a preamp so refer to your turntable manual.
(Some equalizers act as a preamp) You wont hurt it by trying it.
Jan 04, 2013 | Mitsubishi Da-g108 Stereo Graphic...
I have just bought a new Onkyo TX-NR808 and set it up over the week end with new 'accusound' surround sound speakers. Have bi-amp the front speakers. I don't think I am getting very good sound out of it?...
Depending on the amplifier, it might not provide enough power (in Watts) to the speakers. If the speakers require more power, it won't be as loud.
Mar 06, 2011 | Onkyo TX-8222 Receiver
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 21, 2011 | Onkyo TX-8222 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Feb 02, 2007 | Onkyo TX-8210 Receiver
Onkyo TX-8222 Receiver Logo
463 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
