Do I need a new driver? I have unplugged/plugged several times in different USB drives. Is not visible in the drive directory of my Windows PC
Try plugging it in to a different computer.
If it still fails, then the problem either is:
* power-supply (most external drives that have a 3.5-inch disk-drive inside require a power-supply; most that have a 2-inch disk-drive inside draw power from the USB port),
* adapter inside the external case (convert USB interface to SATA interface of the disk-drive) is failing,
* disk-drive inside the external case is failing.
Your best hope is that the disk-drive is OK.
Remove it from inside the external case,
and attach it as a "slave" disk-drive inside some desktop computer, and copy the files.
