PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Screen glare on acer 5610-4610
By smetana on Nov 14, 2007
i was given two suggestions for correcting my screen glare problem. one was to use function + up arrow. this did nothing. the other was that it is an inverter problem. how do i correct that inverter problem?
Comments:
Nov 14, 2007
- i see myself in the screen and because of that, have trouble reading text.
Nov 14, 2007
- can you tell me if this antiglare filter will be expensive? also where I might buy it. does it need to be an acer product for my acer computer?
Best Solution
posted on Nov 14, 2007
Very Helpful)
Poohawk
Rank: Wiz
Rating: 84%, 253 votes
I'm not sure what either of those suggestions would have to do with glare on the screen.
Could you try to describe, in detail, what this "glare" is that you are talking about?
Thanks!
Ron-
Comments:
Nov 14, 2007
- Oh, OK!
There are only 2 fixes for that, that I know of.
1. The first it to do things like, change the angle of the light striking the screen. Change the angle of the screen, close curtains so outside light doesn't strike the screen, change the positions of lamps that may be in the room, or change the position of the computer in relation to the lamps. (Not very helpful, I know)
2. Buy and anti-glare screen and install it on your display. These are thin sheets of plastic that can be cut to fit your display. Clean the surface of the display carefully. Lay the filter on the screen and press into place. That's probably the best fix.
Unfortunately, there is no way of adjusting this on the pc, itself.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 14, 2007
- Here is a link that will tell you all about it.
http://www.powersupportusa.com/products/ef.php?category=pb
Just pick the size that fits!
You might also check on e-bay. They are sometimes available there.
Ron-
Was this helpful?
Yes
No
Solution #2
posted on Sep 28, 2008
Not Rated)
acer0925
Rank: Apprentice
Rating: 0%, 0 votes
i have a acer 5610-4610 laptop and everthing on the monitior is offset to the left how do you adjust it because there is a 4' black strip on the right side.
Was this helpful?
Yes
No
Solution #3
posted on Feb 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
In the hardware department buy tinted window film for under $5 and cut it to size. The lightest shade is best. Don't peel the back off. Clean the PC screen and apply the film with tape. If you cut it wrong, try again. There's plenty left. Voila! Problem solved for pennies!
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
No message.
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
My acer extensa 5420 boots up exery once and awile and after a litle bit of use or a small knock... (More)
Answer
Cannot get cursor to work. What do I do?
Answer
when i defrag my laptop disk, when its finish defragmenting there is always files fragmented, each... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
