Question about Garden
Husqvarna chainsaw starts, runs for a short while and then dies out. I have checked the obvious as well as adjusted carburator. Suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
You may need to rebuild the carb.
Posted on Jul 11, 2009
SOURCE:
Husqvarna 141 starts with choke and then cuts out
If the chainsaw has been used recently i would say It sounds like the screen filter inside the carburetor is dirty item # 507432582 or the metering diaphragm is dried out item # 530035165. Also check that the fuel lines are in good shape. If that doesn't solve your problem you should do a pressure and vacuum test to check the seals and gaskets.
Feb 01, 2014 | Husqvarna Garden
. Have a 350 Husqvarna chainsaw which idles
This sounds like fuel starvation, replace the fuel filter in the fuel tank, if this does not help, when it starts to die just slacken off the fuel filler cap, if it picks up and runs normaly then it is a tank braeather issue, the breather is on the top right hand corner of the fuel tank, replace it.
Oct 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My saw starts fine but will not stay running. I rebuilt the carburator but still will not run.
If it is running fast at idle or you cannot adjust it. You may have a leaky crankshaft seal . Also check the hose and filter inside the gas tank for any breaks or clogged filter.
Sep 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My Husqvarna 136 S/N 91VG/56 runs about 1/2 min. then dies. Start it again and it runs about 1min. and dies.
check air leaks between cilinder and carburator, if its ok- fine, check rebuid carburator.
Sep 16, 2010 | Husqvarna Chain Saw 20" Bar
I have a McCulloch 3516 chainsaw and need advice on how to adjust the carburator. It starts but runs for a short time and dies.
You say runs a short time, seconds or minutes ? Seconds could be carb setting, minutes could be fuel mix ratio. let me know.
Oct 17, 2009 | McCulloch Garden
353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Feb 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
155 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
