Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Daylight savings time
How do I change the time to DST - the keyboard did not automatically change the time on November 4th
  • 4 Answers
Re: daylight savings time
To change date and time. Hold Down FN beside the Right CTRL button and then push F10set the time should start to flash type in time use arrow keys to move form minutes to hours to month etc.
Posted on Mar 15, 2008
Re: daylight savings time - Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Keyboards & Mice
Fn + F10 then use arrow keys
Posted on Mar 11, 2008
I'm waiting until Spring! Mine won't change either
Posted on Feb 11, 2008
0 characters
3 Points
My Wireless keyboard isnt working but the mouse is. I just put in brand new batteries so i know that is not the problem. Help!
Check to make sure you resync the keyboard. Some times, when a wireless keyboard or mouse loses signal, you have to press a "Sync" button on the receiver (or device) to restore the connection. Some of the newer mice and keyboards from Logitech resync automatically, it just depends on what brand and model you have.
I hope this helps! If you're still unable to get it to reconnect, you're probably dealing with a malfunctioning keyboard. Check into the warranty!
Please remember to rate if this was helpful!
Mar 17, 2011 | Micro Innovations Wireless...
I needed to know how to change the time because it will be daylight savings time change tonight.
Cut and Paste this link it will tell you all you need to know
How do I turn off French characters
try pressing the left CTRL + SHIFT keys at the same time to switch it back over (You might need to press them a couple times).
From regional settings (regional and language settings) keyboards/change keyboards, you can remove all the keyboard you don't use and leave only the one you need.
Good luck
Jan 31, 2011 | Logitech (9673120403S) Keyboard
Where is the on off switch??
sometimes there is no on off switch they automaticly turn off to save battery power i know this becasue i own many wireless keyboards and they all turn off by themselves to save battery after a certain amount of time but usually there is a switch on the bottom of the keyboard that sometimes is small and in a corner
Jan 02, 2011 | Dsi FK-760 Keyboard/Mouse
How to activate NumLock as a default? My job requires that I work with numbers the majority of the time so I need to keep the NumLock active. However, each time I log off, the NumLock automatically...
A simple reg edit will do this
For current user:
  1. Start Regedit
  2. HKEY_CURRENT_USER\Control Panel\Keyboard\InitialKeyboardIndicators
  3. Change the value from 0 to 2
For all users:
  1. Start Regedit
  2. HKEY_USERS\.DEFAULT\Control Panel\Keyboard\InitialKeyboardIndicators
Jul 09, 2010 | Dell SK8110 Keyboard
Mouse scrolls automatically
may be its time to change mouse... try & connect any other mouse & see if problem still exists with it.
If not then you need to replace the faulty mouse
Jun 15, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
I recently installed a new printer, but when I try to print it is printing to a file and not printing hard copy
Go into Start > Control Panel >Printers
Choose your new printer by clicking on it once. The right-click on it and choose Set As Default Printer.
Save your changes and from now on, this will be the printer you will print to automatically.
Nov 15, 2009 | Dell QuietKey (310-1235) Keyboard
Set for daylight time
1st, if your time display is not shown on the LCD, press FN and F9 at the same time until the display appear. Press FN key and F10 key at the same time to go into SET mode. Use the arrow key to select and set your correct time. Press ENTER when done.
YBC (/\)
Mar 16, 2009 | Logitech Cordless Desktop MX3200 Laser...
I read another response and found the FN Key and they held down the F10 (Set) Key to use the up and down arrows to adjust the date and time on my keyboard.
Thanks for your help!
Nov 13, 2008 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
843 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
