Computer wont start
Tuns on for 2-3 seconds and shuts off
  • curleybradsh Nov 07, 2008
    computer come on and stay for 2-3 sec and start over. Did change fan in unit
  • veronicadelv Mar 28, 2009
    My computer wont turn on.Dell Dimension 5100
Need help. i have a dimention c521. when i push the power button in. the button turns yellow the fans go on and the yellow button shuts off and the fans to thank you mike
Posted on Mar 15, 2008
    Problem Solver:
  • 8 Answers
This will happen because of Bad RAM, if the RAM of the system is not good the system will restarts continuesly
also the problem with SMPS (power supply unit)
Posted on Nov 28, 2007
  • 121 Answers
Get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system changes then exit.
check the power on pannel pins if they are in a good position too
Posted on Nov 14, 2007
Engine wont shut off
sounds like the key switch is melted.
Jun 16, 2015 | 2003 Ford Excursion
Hi my computer wont start up and making beeping sound
First of all you didnt mention how it gets shut down. So i can say 2 possible ways in which system gets shut down.
First thing is that when you boot windows it will get shut down constantly
Second thing is that it wont load windows. TO be more specific CPU wont get On.
So what you need to do is that If the problem is with the first case you need to see the windows need to be formatted and you can proceed successfully
IF the problem is with the second case you need to get repair the SMPS or you need to see the CPU interior circuits.
I hope it helps.
Aug 07, 2011 | Acer Aspire T310 PC Desktop
The scroll pad wont work to deny application start up. Then it wont move at all. can you help me please?
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | Computers & Internet
Pool heater wont start but when i turn off the pump and start back again the pool heater comes on for 2 seconds and shuts off AGAIN
Heater must have water before it will fire up. There is a delay relay that may be dozing off. Not a bad thing but should be chk'd by a pool sevice.
May 26, 2009 | Heating & Cooling
Picture comes on for 2 seconds then tuns to black screen Sound ok
This more then likely a back light inverter board issue! It can be intermittent or just black an non responsive.
Feb 18, 2009 | Televison & Video
I have a 95 Maxima I changed the fuel injectors and now the car wont start.  so i put the old injectors back and it still wont turn over,  It stay on for about 2 sec can anyone help me
I assume you bled off fuel pressure before you installed the injectors. Try this to pressurize the fuel system. Turn the key to "on" position and wait 5 seconds. AT same time, listen carefully for a buzz sound that means the fuel pump is running to pressurize the system. It will shut off after 5 seconds. Then, turn off the key and wait 30 seconds for the computer power relay to shut off. Then, turn the key to "on" again. Thsi will run the fuel pump for another 5 seconds. Repeat 5 times. Fuel system should be pressurized now.
If it doesn't start now, you may have done something while you were changing the injector. good luck
Jan 09, 2009 | 1987 Ford Tempo
Remote start relearn after removal and install in another vehicle.
turn key on. within 5 seconds press switch 5 times the siren or horn will sound,then push switch 21 times and hit button 2 on remote then turn key off .this sets to gas engine.then start car do the same thing but press button 1 led should light and stay on if this is a good tach wire.did you get the take wire at ecm on drivers side inner fender black plug with white wire or did you just tap a fuel injector wire
Oct 16, 2008 | Scytek 2000RS Remote Control
Ipod second generation
just wait for it to shut down ipods sometimes freeze up
May 05, 2008 | Apple iPod nano 3rd Generation
Have you reset it? Grab a needle or a end of a ear-ring and put it in the hole located right of the ear phone jack, once you hear a button being pressed down, hold for 5 seconds and then it should turn on. As for recongnization, try different USB ports on your computer.
Mar 12, 2008 | Memorex MMP8565 MP3 Player
Computers & Internet Logo
482 people viewed this question
David Payne
David Payne
