Question about OKI B4350 Laser Printer
Oki printer problem
I am unable to print as the message reads tray empty but there is plenty of paper
  • kcplpc Nov 22, 2007
    tried your suggestion but the message still reads no paper in tray 2. The printer has tray 1 and when paper was offered to tray one still says no paper n tray 2
  • Anonymous Mar 24, 2009
    WORKED FINE LAST NITE NOW SAYS ERR 173 NO PAPER AND ITS FULL
    Sergeant:
    Champion:
  • 298 Answers
Possibly a defective paper sensor (small lever in the tray contacts
paper) Try removing, and inserting paper a few times if this clears it
then it was sticking.If that dosen't work then you will have to
disassemble it and inspect the area of the tray switch to determine
it it needs replacement
Posted on Nov 14, 2007
Lexmark T640 printer will not print- get message- media tray empty
Check if the paper tray has enough amount of paper in it. If it has, check if the paper guides are correctly placed and is set to the correct media size.
Aug 02, 2012 | Lexmark T640 Laser Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
I have a samsung SCX 4824 FN printer- message
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 19, 2010 | Office Equipment & Supplies
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
The print keeps giving me a message saying it is out of paper and won't print, the printer has plenty of paper
There is a "micro-switch" that should be triggered by the weight of paper, i.e., no paper in the tray triggers the switch, and the printer reports "tray empty".
So, either the paper is not correctly inserted, so that it does not touch the micro-switch, or the micro-switch is "jammed" into the "no paper" position.
Jan 05, 2010 | HP DeskJet 3650 InkJet Printer
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Nov 20, 2009 | HP OfficeJet 9120 All-In-One InkJet...
Paper won't feed. Message says paper tray empty but it isn't
Hi
Please press the button above HOME and it should change the tray in which you are printing from .
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Office Equipment & Supplies
OKI B4350 Laser Printer Logo
454 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
