Question about Vacuums
Bissell proheat pro tech model 7901-3 smart mix dial and valve assembly
I disassembled to clean out some hoses. The smart mix valve fell out and I don't know what position it was in in relation to the smart mix dial on the outside of machine. Can you help or do you know where I could obtain a schematic that shows the way to do it. Thanks Boyd
    President:
  • 1,673 Answers
Turn the knob to the water only, put the piston on the bottom of the knob then turn it slightly so it doesn't fall off, Start to put the cover on, when it is straight, turn the knob to the water only selection and push the top all the way down. The piston should have gone into the hole and the knob should turn easily.
Posted on Feb 22, 2008
I don't know what happened, but it seems my unit is not pushing down all the way to engage the cleaning solution. Also when I turn the knob for the POWERDRIVE, the entire handle pulls out and the unit shuts off
Posted on May 26, 2008
    Problem Solver:
  • 9 Answers
Great advise. I repair these all the time! This solution is BETTER than the way I was doing it. Thank You!
Posted on Nov 30, 2008
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
Replacing smart mix plunger bissell proheat model 7901 procedure for proper installation
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to replace diverter valve model 7901 bissell pro heat steam
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
g,hk
Apr 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell ProHeat 7920 Carpet Cleaner
I managed to sort this. The small plunger valve sits in a little square crevice next to the smartmix dial - it does NOT sit in the middle as it first seems. You then have to get the lip of the smartmix dial to sit in the cut out on the side of the plunge valve so that it moves up and down when the switch is turned.
It take patience, but it is possible - no need to use any force.
Dec 18, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Nov 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
1,186 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
