Hi Rosie, the unit would have to be taken to one of our authorized service centers for repair. You can located an authorized service center at the following link: http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav, Thanks, JT
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
SOURCE: Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Testimonial: "Thanks so much. Great solution."
SOURCE: i need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with
instructions here.
I hope that helps.
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
