Garden Logo
Chester Baron Posted on May 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacing a primer bulb on a 22' murry 5 hp lawnmower
jim slinsen
Level 2:
Habit-Forming:
New Friend:
  • Expert 54 Answers
  • Posted on May 08, 2015
jim slinsen
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
54
Questions
Helped
10440
Points
181
Pick up a replacement kit at a auto parts or hardware store, they are normally held on by two screws
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 • Toro Garden
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 • Garden
2answers
Can I replace just the primer bulb
yes useing a thin small screwdriver slide it down the side and work the spring slowly out revers this to put a new one in
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
I have a 22 inch self propelled recycler that will idle for hours,but as soon as you engage the self propel and start mowing it stops after 5 minutes.
This sounds like fuel starvation. This is usually caused by debris in the fuel float bowl or a dirty fuel filter (if used). Remove the fuel float bowl and clean out the debris. With the bowl removed use a spray paint can lid as a catch pan and check fuel flow. With the float down it should fill the spray paint can lid in about 10 seconds. If you do not have this much fuel flow you need to inspect the tank outlet port, fuel lines and filter (if used).
The 20029 & 20099 models came with either a Briggs & Stratton or Kohler Courage XT7 engine. I need to know what engine you have to provide any diagrams on what to check or clean. A n engine model number would be even better. (Please!) Since the post is labeled with the 20099 model I will cite that as a reference. This SERVICE manual should help you with repairs:
http://www.kohlerengines.com/onlinecatalog/pdf/tp2601_308.pdf
See page 27 of the manual for fuel filter location. (Optional if used) AN exploded view is on page 31.
If you have the primer bulb model see page 24 and note the ondition of the primer bulb and primer bulb hose. Any hole in the primer bulb or cracks in the primer bulb hose can also cause this symptom.
If you have the Briggs and Stratton engine (Model 20029) I need the engine number to get you the correct manual data please. Otherwise...this should help you resolve the problem.
Thanks for choosing FixYa,
Kelly
2answers
My primer button as broken how to replace it and where to buy the
Lowes Home Improvement store carries them, also lawnmower repair stores have parts departments that have them. Mine cost about seven dollars.
1helpful
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 • Garden
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Top Garden Experts
Jay Finke
Jay Finke
john h
