Cars & Trucks Logo
A
Anonymous Posted on May 07, 2015
We recently purchase a 2005 kia sedona and when put in reverse it beeps sometimes continued beep till put in drive( no back up camera) can anyone tell me if this is normal or why it does this?
jimcatherina
Level 3:
  • Master 576 Answers
  • Posted on May 07, 2015
jimcatherina
Master
Level 3:
Answers
576
Questions
Helped
128464
Points
1600
Hi it is normal it's just an audible warning that you are in reverse. Regards Jim...
Bill Boyd
Level 3:
Top Expert:
  • Kia Master 53,816 Answers
Bill Boyd
Kia Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949594
Points
172802
Talk with a service centre but it would not be unusual for the vehicle to have a reversing alarm fitted especially if the alarm stops on selecting forward gears
1helpful
2011 Kia Sportage and when in reverse it continuously beeps until put into drive. I tried to wipe the sensors on the bumper but its still doing it. What can I do to fix this?
Maybe you can't. That is probably not a fault and nothing to do with the parking sensors. Many vehicles have a safety feature to alert anyone behind you that you are reversing. It operates from a switch when you select reverse gear. There have been tragic tales of children and adults run over on home driveways. The beep alarm helps to prevent these accidents. This scenario applies if it is louder outside the vehicle than it is inside the vehicle. If the beeping is inside only, there is indeed a fault. The only way to find which sensors is faulty is to have an auto electrician connect a pro grade scan tool computer and check the parking sensors.
https://www.justanswer.com/kia/cnn3y-backup-sensor-system-2011-kia-sportage-not.html
and
https://www.google.com/search?q=2011+kia+sportage+reversing+alarms
Where to find fuse for relation of the reverse parking sensors in kia sedona ls 07plate
kia sportage parking sensor - ABMforum.com
abmforum.com/kia-sportage-parking-sensor.html
kia sportage parking sensor installing rear parking sensors fitting rear parking sensor strip ... the pre-drill hole on 07 sportage 2007 kia sportage lx navigation wiringparking sensors. ... I cannot see any fuse which may relate to them. ... with their rear parking sensors Even if all is clear behind I now get a continuous beep and ...
Urgent help needed - towbar electrics - Kia Forum
www.kia-forums.com/kia.../71610-urgent-help-needed-towbar-electrics....
Aug 28, 2011 - 10 posts - ‎3 authors
I'm in the middle of fitting a genuine Kia towbar (made by Witter) to my SW. ... Need help again - Does anyone know the location of the PDC Control unit (parking sensors)? ... Drives: Kia Ceed SW 1.6 MT LX A8 ... with the loom which connects to the fuse box does not seem to attach to the rear lighting loom.
[PDF]2007 Sedona Owner's Manual - Kia Canada
My2002 kia Sedona is beeping the park brake light is on my parking brake I think its broke and the beeping noise is driving me crazy is there anything that I can do
try looking for the switch on your hand brake lever, they do have a tendency to cause problems, it could be that the switch is not being activated when you put the hand brake in the off position, refit and adjust it. if this doesn't work try unplugging it..
2helpful
2answers
Creeking sound when putting 2005 sedona into gear
I would guess Mounts too.
maybe check te Strut mounts as well, they torque up as teh car goes from neutral to a gear ( forward or reverse)
2005 kia sedona brake light on dash stays on and continous beeping.
Two things will cause the brake light to come on.
1. The e-brake lever is not in its fully retracted position.
2. the brake fluid in the reservoir is low.
Check both of these first. If there is no problem with either let me know.
Thank you for using Fixya.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
6helpful
2answers
Jaguar XK8 2005 beeping/no reverse sensors working.
I have the same problem on my XK8 2005....did you find a solution?
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
