The Micro SD Card Slot is on the side of the tablet in between the Headphone Jack and the USB Port.
If the card slot has a symbol near it with the letters "TF" than this is OK.
"TF" stands for TransFlash which is a common name for SD.
flash the tablet with firmware.download correct firmware to pc.copy to micro sdcard.insert card into tablet and do a factory reset,select reboot. or power off,then on,it'll do the rest,take out card and power on.
Please try the following solution to clear all your data, return to the factory. thanks.
please email back to me , I will forward the attachment. this solution I got it from china Step 1. Please use the zt-update.zip file in the attachment, and extract it to the root directory of TF card. Please be noticed before you update,you will finally get the zt-update and files as below (Assume F: is your TF card). F:\>cd zt-update F:\zt-update>dir 2012-09-20 09:56 <DIR> . 2012-09-20 09:56 <DIR> .. 2012-09-20 10:00 24 command Step 2. Put the TF card into TF card slot, then press the "Volume Minus" button at the same time to press the power-on button. Step 3. Check the screen output, it will show like the following: [img src="https://mail.google.com/mail/?ui=2&ik=31e70cdd74&view=att&th=1409b1489bc64f36&attid=0.0.1&disp=emb&zw&atsh=1" class="">
After rebooting, it will be OK now. Hope the way above can solve your issue, please let me know your result, many thanks.
