Question about Hitachi 43FWX20B 43" Rear Projection Television
Red color alignment problem
Overnight this problem appeared. All shapes on the right hand side of the screen have a red shadow to the right and figures on the left hand side of the screen have a red shadow to their left. As the news ticker goes across the bottom of the screen a red copy of all letters appears to curve outwards from the background into the screen and follow the letters, gradually matching up and aligning properly in the middle of the screen, then the red copy letters gradually seem to fall back from the screen and curve back into the depths as if the red were on a circular screen that exists behind the real screen. What repair will this need. I know this is confusing, but the problem does not exist in the middle of the screen, just on the outer 1/3s of the screen. What controls and aligns the red in this thing? Any thoughts and help will be greatly appreciated. Bob W.
  • Bob W Nov 16, 2007
    This reply has misspellings and poor syntax and grammar. While this person may know something about TVs, this info is of no good to me and I do not accept this response in trade for my 10 bucks. Please have someone respond who can write decent English. I was able to correct the red lines after about 2 hours of work with the covergence controls in the remote. The picture was beautiful for 24 hours, then suddenly went back out of whack. Is there a way to lock the convergence after you orrect it?
    I was able to correct a massive red line convergence problem after 3 hours of tedious labor, and the picture looked beautiful for 24hrs, but suddenly went back out of whack. Can one lock the lines after they have been fixed? If I look at the innards of this thing what do I look for, and is this problem better left to pros? I have little experience with solid state boards. Thanks. Bob W.
  • 1,694 Answers
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Posted on Nov 16, 2007
  • 143 Answers
All you have to do for you to fix this is solder bad solder connections on convergance board if the problem does not go away the replace the stkyou might have more than one replace them all
Posted on Nov 15, 2007
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
The screen seems to have two of the same image, green and red.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
Red shadow on right hand side of screen
Have you tried the customer convergence alignment procedure, to see if it will adjust the shadow out. You'll find it i listed in the on the on screen menu.
Sep 01, 2009 | Samsung Televison & Video
LG 700B color problem
there isent realy anything you can do about this if im understanding this right i beleave the color tube might be toast.
Sep 13, 2008 | LG Studioworks 700B (White) 17 in.CRT...
Upper screen
You can buy replacement screens fairly cheaply.
Check your local area, there is bound to be a console shop that will be able to do the lot for you.
Search for words like mod chip, console mod etc with your city name
EG mod chip new york
Apr 13, 2008 | Nintendo DS Lite Console
Select each color. all you have to do is align it with white by using the directional arrow keys - Simple! For fun, Grab a pair of red and blue 3d glasses and offset the red and the blue channels. Yes, I have too much time on my hands. Good luck :)
Apr 07, 2008 | Hitachi 60SX13B 60" Rear Projection...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Color shadows
PVAT!Check for evidence of coolant leak on pcb's, If none found,replace convergence IC's,then align convergence in servicer mode.Check service literature for procedure.
Sep 02, 2007 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
