Question about Sony PlayStation 2 (PS2) Console
USB Port Problems
My husband and I have two Playstation 2's. My keyboard has been having issues lately (it'll stop working and/or the letter will be stuck and repeat) we believe it is a USB Port Issue.
We believe it is a USB Port issue since we have traded the keyboards/adapter/cables from the working PS2 port to the other PS2 port and the same issue presents itself. The keyboard/adapter/cables from the non-working PS2 was traded with the working PS2 port and the keyboard will then work properly.
Is there anyway to fix this issue? I have tried cleaning the port.
  • 709 Answers
Hi Jen Storm,
It is probably dirty on the inside. My guess is that Dust has built up on the motherboard and some moisture in the air has turned it to a conductive dust. This will casue a probably like you are seeing. Either Clean it up real good yourself or send it to a repair shopp. If you are looking for arepair Shop, Click on "Repair Directory" at the bottom of this screen, and Click on "Video Game Consoles" Pick a good Repair shop in your Area, or Nation.
Posted on Nov 20, 2007
On a hp pavilion a 1 1 10n I did somehing to cause
computer keyboards can have faults in several ways, but the most likely is liquids being spilt on them, causing them to do odd things or to just stop working completely.
There's loads of people having problems with this series of keyboards. With some keyboards the speed is wrong for them being checked (USB versions) and you can easily type faster than the keyboard controller can respond so it just goes nuts :-(
Notably, lots of laptops have a problem handling fast typing and tend to throw the cursor around or mis and add random letters.
Try a different keyboard just in case. Check its wire and connections for breaks/damage. Plug it into another USB port if possible some towers give lower power/resources to some USB ports - especially ones on the front of tower cases.
Also, some odd BIOS's allow you change the typing rate/speed (usually quite old ones though). If that value doesn't match your keyboard enough you can have problems.
Aug 06, 2013 | HP D8597A Keyboard
Keyboard not working on my Dv9700
Try using a USB keyboard. If that doesn't work, I'll have an indication of possible causes. I want to isolate the keyboard from possible motherboard problems.
Get back to me with a comment because I'm following your problem.
May 29, 2012 | Computers & Internet
Keyboard stopped working
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
May 28, 2012 | Computers & Internet
I have toshiba Tecra 9000 laptop, its USB ports and Keyboard EXTERNAL port is not working. please help me
It's a common problem with the Tecra 9000's - either one or both USB ports and sometimes the external KB port along with it. The 2 USB's and external KB port (and the TV out port next to it) are all located on the same daughterboard that plugs into the motherboard, and in your case, more than likely the connector on the motherboard is bad (gotten loose). There's no easy fix for this unless you've got an ultra-fine soldering tip, good soldering skills....
How about a workaround? A PC card (PCMCIA card) that gives you 2 or 4 high speed USB 2.0 ports - it'll stick out a little on the right hand side, but in return you'll have fast USB ports, and you can use a USB keyboard with the thing.
Sep 14, 2011 | Toshiba Tecra 9100 Notebook
My husband has an HP computer and is using windowsXP. Suddenly, he cannot enter any typed infomation as required during a search, but his cursor works to go to the blank field. He cannot type into the...
Your keyboard USB cord has probably become loose. Try reseating the cable into another USB port, or just reseating it if the keyboard uses a keyboard cord.
If this doesn't work, try a different keyboard (if you have another one around the house).
You may have either a bad USB port, dirty port, or bad keyboard.
please rate my solution!
Jul 17, 2010 | HP Pavillion s7420n PC Desktop
My y key just stopped working on my macbook (I am on my husbands for this message) all other letters are fine. Any idea what I can do to fix this? Thanks, Deb
What you can try is hooking up a USB keyboard to try and see if that Y is working now if it workes on a external keyboard then its time to use your apple care to have the keyboard switched out. I know you where looking for a better answer then this but the issue is complexity and time. I want you to diagnose your problem and solve it that way not fix the wroung problem make sense? So if the external keyboard wroks then the mac book keyboard will need repair.
Thanks nad please do be considerate when passing threw fixya to leave feedback and ratings.
May 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
Please check the Fixya repair directory for a list of people who will repair your keyboard port near you.
Mar 02, 2009 | Computers & Internet
Keyboard problems
yes in some issues i have encountered the ribbon that plugs the keyboard in may be corrupted or you may have a bad keyboard
Aug 10, 2008 | Samsung P10 C XTC 2000 Notebook
Minimal information to go on. Since you didn't specify whether this is a laptop or desktop, I'll respond with the assumption that it's a desktop.
Power off computer.
Install new (known working) keyboard.
If that doesn't correct the problem, your issue is probably with the PS/2 or USB port your keyboard is plugged into.
If you are using a USB keyboard, first try moving it to a different USB port, then booting. If that doesn't help, try a PS/2 keyboard.
If you cannot get a known good (working/new) PS/2 keyboard to work in replacing a PS/2 keyboard, try a USB keyboard.
Jul 22, 2008 | Computers & Internet
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
