I had several codes on my code reader,po300 ,304,305,306,p2196,p2197,p2198 ,I changed out the coil.The reader had 1 code p2197 o2 sensor,then I checked the oil,it was completely out except the tip f the dipstick the car still runs but really poorly,there is a knocking sound and it shakes. Am I screwed or is there still hope?
P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0310 Cylinder 10 Misfire Detected P0311 Cylinder 11 Misfire Detected P0312 Cylinder 12 Misfire Detected P0313 Misfire Detected with Low Fuel P0314 Single Cylinder Misfire (Cylinder not Specified) P0315 Crankshaft Position System Variation Not Learned P0316 Misfire Detected On Startup (First 1000 Revolutions)
Read more at: http://www.obd-codes.com/trouble_codes/
Copyright © OBD-Codes.com
P2195 O2 Sensor Signal Stuck Lean Bank1 Sensor 1 P2196 O2 Sensor Signal Stuck Rich Bank1 Sensor 1 P2197 O2 Sensor Signal Stuck Lean Bank2 Sensor 1 P2198 O2 Sensor Signal Stuck Rich Bank2 Sensor 1
Copyright © OBD-Codes.com http://www.obd-codes.com/p0002
