Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
14.4v cordless drill...battery does not get a full
By waconia on Jul 10, 2009
14.4v cordless drill...battery does not get a full charge
Solution #1
posted on Jul 14, 2009
Somewhat Helpful)
stairmaster
Rank: Wiz
Rating: 91%, 9 votes
Batteries retain a memory. If you only drain the battery half way and than recharge all the time it will only keep half a charge. Try running it all the way down and than recharge it, this can take some time. Let it run till it gets very very slow and almost stops, but don't go past where it stops or it will not take a new charge at all. It does not always work, but worth a try before buying a new one. Good Luck
Was this helpful?
Yes
No
Solution #2
posted on Aug 04, 2009
Not Rated)
Gerry_D
Rank: Guide
Rating: 85%, 9 votes
I don't know how to navigate this forum, but as to batteries not getting up to full charge, I have successfully "repaired" batteries for the Black and Decker cordless drills I have. The answer is one or more cells in the battery are internally shorted.
The methods to fix that problem are here:
http://handymanclub.com/community/forums.aspx?g=posts&t=42166
and here:
http://handymanclub.com/community/forums.aspx?g=posts&t=44094
Read all the posts and pay particular attention to the single cell method I have used.
Cordially,
Gerry
Was this helpful?
Yes
No
Solution #3
posted on Jul 29, 2009
Not Rated)
pjtoolrepair
Rank: Apprentice
Rating: 0%, 0 votes
After you have discharged the battery - put in a air tight plastic bag in the freezer for 1/2 an hour - then charge as this drops the temp so it takes longer to get to full charge temp - for tech people with a multimeter :-)
- don't drop battery too far below 0.7 volts per cell as this can also damage the battery cells further (most Ni-Ca batteries are 1.2 volts per cell) - this doesn't work for Li-ion as they can be charged from any charge state
Was this helpful?
Yes
No
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were... (More)
Answer
i get a yellow light with some batteries
Answer
Probably in the wrong cattegory but I need to find the tp2 mkv trailer pack- manual. As I want to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Drills / Driver Experts
Top Garden & Power Tool Repairmen
in Lancaster, PA
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
