First I would request you to provide the name and the model of the printer which would helps us to provide you more specific troubleshooting steps for your type of printer. I am providing you some of the trouble shooting stpes which should be ideally done in cases like papaer jam:
* Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
* Turn off the printer.
* Remove any paper trays. Inspect them for wrinkled or damaged paper.
* Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
* If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
* If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly . The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
* If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
* Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
* If the printer paper jam message still appears, then there is still some paper in the printer.
My Epson Photo R265 is showing all an X on each of the cartridges on the status monitor, and telling...
(More)
My Epson Photo R265 is showing all an X on each of the cartridges on the status monitor, and telling me that cartridges are incompatible when I try to invoke the cleaning cycle. Please note this is with brand new compatible cartridges that have worked fine before and that the message is saying "incompatible" not just telling me that the cartridges are not Epson. Dave
trying to get printer connected to my laptop to print-would like to be able to scan als0-have...
(More)
trying to get printer connected to my laptop to print-would like to be able to scan als0-have misplaced CD that came with printer for setup-can it be downloaded on the web?
