Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Unable to install KB928366
my computer is unable to install Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1 (KB928366) despite initializing.
  • 306 Answers
Re: unable to install KB928366
Update the OS to SP2. more stable and secure.
Posted on Nov 14, 2007
0 characters
3 Points
How to Slipstream Drivers on Windows XP using WINNT.SIF
So you have already slipstreamed Service Pack 3 using one of the many tools available I prefer Autostreamer v1.0.33 Its Autopatchers little brother and takes the legwork out of uncompressing and recabbing. I then tend to integrate WMP11 using boooggy's slipstreamer this allow then installation of all associated WMP11 hotfixes.
When all this has been done its a good idea to slipstream all the post SP3 hotfixes to the I386 folder and also copy the WINNT.SIF file that you have created to perform an unattended install with drivers.inf files.
One of the best update packs available is Xables the latest version is v2.0.2 (August 2010) download link HERE this what the pack includes History at the point of posting August 2010 its stands at around 219 post SP3 hotfixes its only missing about 12 hotfixes mainly NET. Framework Service Pack fixes. Plus 12 optional updates you will need to go to the update website to get those if you really want them, or here is a list so you can google them
  1. Update for Windows XP (KB961118)
  2. Update to .NET Framework 3.5 Service Pack 1 for the .NET Framework Assistant 1.0 x86 (KB963707)
  3. Security Update for Jscript 5.8 for Windows XP (KB971961)
  4. Update for Windows XP (KB976662)
  5. Security Update for Windows XP (KB981332)
  6. Microsoft Browser Choice Screen Update for EEA Users of Windows XP (KB976002)
  7. Microsoft .NET Framework 3.5 SP1 Update for Windows Server 2003 and Windows XP x86 (KB982168)
  8. Microsoft .NET Framework 1.1 SP1 Security Update for Windows 2000 and Windows XP (KB979906)
  9. Microsoft .NET Framework 3.5 SP1 and .NET Framework 2.0 SP2 Security Update for Windows 2000, Windows Server 2003, and Windows XP x86 (KB979909)
  10. Microsoft .NET Framework 3.5 SP1 and .NET Framework 2.0 SP2 Update for Windows Server 2003 and Windows XP x86 (KB982524)
  11. Security Update for .NET Framework 2.0 SP2 and 3.5 SP1 on Windows Server 2003 and Windows XP x86 (KB983583)
  12. Cumulative Security Update for Internet Explorer 8 for Windows XP (KB2183461)
When you have installed this you are ready to copy your WINNT.SIF file to the I386 folder and create the drivers folder in your Windows Source Folder, then use Signets DriverGrabber v0.51b on your existing installation to get all the INF DLL and EXE files that you will need for your driver folders
Create an $OEM$ folder and place inside it a folder called $1 and then another inside that called Drivers then a folders for each driver make sure that you number then to ensure that chipset is always first.
001_chipset <-----this must be first
008_ <------
more folders you need to add to the OemPNPDriverPaths
these are the paths that I have specified in the WINNT.SIF relevant section, you MUST add these lines in the [Unattended] section OR it will fail on you. !!!!
NOTE: The OemPnPDriversPath can't search sub-folders to all the files that Driver Grabber will give you will have to copied them to the relevant numbers root folders, and remove the subfolders for each driver remember that each path is separated by a semi-colon
add an extra semi-colon at the end, it might fail !!!
UpdateInstalledDrivers = Yes <---- this line is critical to make sure
All you need to do to complete this process is change these two sections to suit your OEM Licence and Owner Details.
AdminPassword="" <------- this can be encrypted using sysprep
ProfilesDir="C:Documents and Settings" <------ you can change this
FullName="your name"
OrgName="your organization"
ComputerName=your computer <----- note that there are no "." on this
FINAL NOTE: if you are using OOBE.INI in the either the $OEM$\$$\system32\oobe folder OR a cabbed (use Compression Bin by Jcarle) to create the OOBE.IN_ in the I386 folder, to set up new users (max 6 admins only) then make sure that you don't use these three lines in your WINNT.SIF to avoid any setup errors on the Out of Box Experience.
[Unattended Section]
AutoActivate = Yes
OR you will get a Out of Box Experience Error after the install as these skip the Create User Accounts and Set Up Internet Screens
If you have any other problems add these sections to your OOBE.IN_ and WINNT.SIF files that you have in your slipstreamed I386 folder
= Yes
AutoConfirm = 1
Offline = 1
Registration = 1
ScreenResolutionCheck = 0
IntroOnly = 0
NoIspPreconfig = 1
JoinDomain = 0
AdminPW = 0
SkipAutoUpdate = 1
remember to keep your OOBE.INI file so that you can edit it before you cab it with compression bin or makecab.
on Aug 22, 2010 | Microsoft Windows XP Home Edition
Error code 643
Try this for starters:
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:…
Then run Windows Update again, to install KB929729.
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
2. Now see Resolution Method 2 in
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
2) Microsoft .NET Framework 1.1 Service Pack 1
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
Please follow the steps above and if still problem persist please lets us know
Oct 20, 2009 | Operating Systems
1 Answer framework 3.5 service pack 1 framework 3.5 family update for. net version 2.0 through 3.5 (kb951847) x86
ya now a days some software runs on net frame work 3.5 sp1 for nero 9 etc. if u dont have it. ols refer to microsoft site to download the software. it is free to download at no extra cost.......
Oct 13, 2009 | Microsoft Operating Systems
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
133 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
