Question about Ford 2005 E-450 Cutaway
Ford f450 fuel pump reset switch - Ford 2005 E-450 Cutaway
  • oldmechanic Jun 26, 2017
    Hi Kevin Patrick, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • Ford Master
  • 83,810 Answers
Posted on Jun 26, 2017
Where is the fuel filter located in a 2011 ford f450 super duty engine?
google : 2011 ford f450 super duty fuel filter location
May 12, 2018 | Ford Cars & Trucks
08 f450 ford truck
Computer needs to be reset. Dealer is your best bet.
Jul 28, 2014 | 2008 to 2009 Ford F450 Truck Super Duty...
2002 F450 will not start
Do you have power to the starter when the key or start switch is engaged ?
Jul 15, 2014 | Ford F-450 Cars & Trucks
No fuel pump sound on a 2005 f450 v10 when the key is turned on and wont star
Check the inertia switch. That switch kills everything.
Also, make sure you don't have any "theft" codes as this will also not allow the pump to turn on.
Assuming you checked fuses and are getting juice at the pump wire.
Don't need to say it but I will. Never check a used fuel pump outside of the vehicle. They do blow up!
Sep 25, 2013 | 2008 Ford F 450 Super Duty
Does a pto pump come stock with a 2012 f450 diseal. i need to hook up my hydralics for my boom and car puller
Sounds like you are talking about a Ford F450 diesel truck. Try posting this in the Cars and Truck section or give the local Ford dealer a call. This particular forum is for pump problems, not what a manufacturer includes on their vehicles. Good luck.
Sep 29, 2012 | Delavan 90800 PTO Adapter, Quick Coupler,...
My f450 cranks but not start, i was in the rd and when i release the gas pedal the truck shut off. 1998 ford f450 super dury
I Had a dodge ram that did that wouldn't start.. I had to buy a crank position sensor.. I don't know if fords have them but worth trying out. or it could be fuel pump is week..which is common. I hoped I helped..
Mar 10, 2010 | Ford F-450 Cars & Trucks
2008 Ford F450 fuel pump relay fuse keeps blowing.
the fuel pump and radio are not on the same circuit, most liokely the fuel pump is shorted, that is the most common cause, get under the truck and disconnect the fuel pump connector at the tank, if the fuse doesn't blow then u need a new pump.
Dec 05, 2009 | 2008 Ford F 450 Super Duty
Ford F450 motorhome will not start
It may be the evap system. Could be as simple as the gas cap. try taking the gas cap off and starting it. If it starts then its the gas cap causing a vacuum. if not, then it could be:
1. Fuel filter.
2. Fuel pump. undo the fuel pipe into the engine and check to see if fuel is being pumped. disconnect the coil lead so engine doesn't start. Be very careful and make sure you put a container to capture the fuel.
3. If fuel is being pumped, then it could be the purge valve and/or vapor cannister. If these are faulty, it could cause a vacuum and vapor lock.
frankly, the fuel system isn't something you want to mess with if you are not a qualified mechanic.
try these easy forms of diagnosis to see if the gas cap is causing a vacuum, or if your brave enough, try the to see if the fuel is being pumped into the engine.
Good luck
Oct 03, 2008 | 2004 Ford Super Duty F 450
Ford 2005 E-450 Cutaway Logo
1,206 people viewed this question
Top Ford Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you a Ford Work Safety Expert? Answer questions, earn points and help others
