Question about Sunbeam Transformer (ICTRBA) ATX Full Tower Case
Sunbeam Transformer ATX Full Tower Case
I have an Asus P5K Motherboard in this case and the internal cable for the front panel audio is not long enough to plug into the motherboard (unless I want to drill a big hole through my video card). Is there some form of extention cable available for this?
  • mosley1826 Jul 26, 2008
    the audio cable for the mic an headphone is to short. In order for it to fit I lose to pci slots. The cable should be at least 30inches to avoid losing PCI slots.Every where I look i can only find 24inch cable.Can anyone solve this problem
  • 62 Answers
If you can't find it HERE, then I would try Radio Shack.
Posted on Dec 30, 2007
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
Motherboard: ASUS P4SD Motherboard Specifications
Board Form Factor: uATX
uATX stands for Micro-ATX,
HOWEVER, the Power Supply is an ATX form factor,
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
Manual #1:
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
I have a sunbeam transformer what kind of graphic card do i use? i cant find it at all on the internet
It's not the case that counts, it's the motherboard in it. Find what mb you have and see the video slot in it.
Aug 01, 2011 | Sunbeam Tech TRANSFORMER IC-TR-B ATX...
Hello, I recently purchased all new computer components, including a Diablotek EPIC ATX Mid Tower case. I have the system complete and running. At first I plugged a USB device into the front left USB...
Hi Red,
I had a similar problem on a different case though.They might have similar causes.
The front usb port circuit board was connected to the MB with a ribbon cable. The prior owner had the cable attached backwards. It worked fine, until you plugged in a USB device, instant crash.
Can't say for certain this is what is happening with you, but it is a possibility.
I'm sure you already know, pin 1 is the striped cable. On the board pin 1 has an arrow.
Best regards
Feb 05, 2011 | Diablotek CPA-802 ATX Mid-Tower Case -...
I have a Ultra M923 Full Tower ATX Case ATX and the lcd screen doesn't work, is there anything i can do to fix it?
@ PaulMo..
You need to research the question and product at hand before posting a solution, Flyner1990 was referring to the LCD panel on the Ultra M923 Full tower case and not a monitor or video card.
The Ultra M923 has known issues with the front LCD panel, either they work or they dont. They are not accurate either.. Solution is either replace the case with something else or disconnect the LCD panel's sensor's and purchase another fan controller. I too own this case and love the design but having issues with the front panel as well and my fix was installing another fan controller/monitor..
Feb 22, 2010 | Ultra Products Ultra M923 Full Tower ATX...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Power Up ATX Mid-Tower case TC3j-4032 P Wiring
The front audio in this case does not support HD sound. To get it to work you must instal the "HD Sound Application" that came with your hardware and disable the "Detect Front Panel Jack Detection" option. You'll have to manually switch between the two inputs.
Mar 09, 2009 | Computers & Internet
Front panel all mashed
Sep 29, 2008 | Sunbeam Transformer (ICTRBA) ATX Full...
Expasion slots don't line up with motherboard card slots
When you buy Motherboard there's a back plate included in the box, you don't have to drill the plate.
If the palte not included in the box you can buy it also where you purchased your Mobo.
Mar 08, 2008 | Sunbeam Transformer (ICTRBA) ATX Full...
Chassis help
go to this site and download usa pdf manual and go to page 28 for instructions
Mar 31, 2007 | ASUS TM-230 Micro ATX Mini-Tower Case
Sunbeam Transformer (ICTRBA) ATX Full Tower Case Logo
212 people viewed this question
Top Sunbeam Computers & Internet Experts
David Payne
David Payne
Are you a Sunbeam Computer and Internet Expert? Answer questions, earn points and help others
