2004 Kia Sedona Logo
n
neil Posted on May 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiring diagram hi I am trying sort out batt going flat,traced it down to Audio fuse, with it removed batt fine but no interia lights,no alarm,central locking, is there other in line fuse to find/remove? or any one got idea to fix ? cheers in advance for any help
Al Kizina
Level 2:
Sergeant:
  • Expert 170 Answers
  • Posted on May 06, 2015
Al Kizina
Expert
Level 2:
Sergeant:
Answers
170
Questions
0
Helped
65620
Points
551
I would have the battery tested. The security alarm normally draws power when the car is not running. If the battery is not fully charged or will not fully charge, the onboard computer and the security system may drain enough power to make a bad battery go dead.
You could check the wires at the fuse block to see if more than one wire is attached to the output side. Most connections are made in the wiring harness and would be difficult to find. Are there any hidden light bulbs that could stay on? Do all the systems on that fuse work properly?
  • neil
    neil May 06, 2015
    I had batt alt tested and both fine,it's a parasitic draw from one of the systems mentioned, need to know how to separate them from each other so as to determine which one is faulty
  • neil
    neil May 07, 2015
    Hi Al will take fuse box off and check how many wires etc. plus only problem with anything that shows is elec Ariel goes up and down when batt first connected!apart from that everything works fine, but that has always happened from the car being new !
1helpful
No power to fuel pump
Hi,fist thing if you havent already try the fuse if not the fuse then try to get a wireing diagram and trace the wire and make shore there are no brakes in the wire,or rewire a new cable.
hope you sort it out.
Ford transit connect central locking
You may have two bare wires touching creating a short. Trace out the wiring. You can get wiring diagram off yahoo.
Wiring Diagram for tracing parasitic drain needed
Check your trunk and dome light circuits.
2005 prius fuse location 39 a 15 amp keeps blowing, central door lock, radio and dome light
You will need to buy a copy of the factroy wiring diagrams for the car and track down all the wires that run off fuse 39. There is no easy way to find a shorted wired, read the diagrams and trace the wiring and look for damaged wires.
Radio fuse keeps blowing in my 97 acura rl
The only thing you can do is to trace the circuits that are powered by that fuse. Nobody can do that online. I would recommend getting a wiring diagram if you are going to try to figure it out yourself. You will need a multimeter that can read amperage also.
Alarm problems(alarm wont activate,1995 factory system,red light not on on center console,no power to light,checked fuse,it was ok,traced wired to relay,how do you check relay?
Relays tipically have a diagram on them depicting which terminals are the switch and which are the signal try using jumper wires to the sensor terminals and listen for a click.
1helpful
2answers
Volkswagen passa1999 all electric windows failed no interior lights central locking not working is this common fault and how can i fix it
on the Drivers side Fuse box check fuse 14 its a little red one usually i just fixed that last night after searcvhign all over for a fix . wife helped me trace the problem in the Bentley manual shes good at diagrams. didnt think of checking the mini fuses but that was it .. it was effectign car alarm sun roof windows and door locks
1helpful
1996 Volvo 850 GLT Fuse #15 keeps blowing out
Hi!
Since you've got a '96 I assume your #15 fuse is 10 amps and for the following components:
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System, Oil Level Sensor, Seat Belt Reminder, Data Link Connector.
Turn ignition to OFF, turn off all interior lighting (by operating the selector inside the car), close all doors, wait about 20 seconds and insert a new fuse. If the fuse is blown immediately upon insertion my guess would be that you have an aftermarket audio system with faulty wiring or maybe something is wrong with you Data Link Connector. If that is not the case the problem might prove a little bit harder to find, and you'll definitely need a wiring diagram. Check this site:
http://www.volvoclub.org.uk/volvo_workshop-850techdocs.shtml
If the fuse is not blown immediately upon insertion: Good, the components affiliated with the fuse can then be grouped by what ignition position they are active at (OFF, 1, 2) and tested individually.
POSITION OFF:
- Door open light, courtesy lights, glove box light, trunk light, remote central locking system.
Make sure the glove box light really is turned off when closing the glove box.
After that it's simply a matter of testing these components one after the other (with the ignition at position OFF) by opening/closing doors, turning on/off trunk light etc, checking the fuse between each component test.
Make sure that the interior lighting is turned off when you test the central locking, or else you might end up faulttracing central locking when the problem was with the interior lighting :)
(Since the interior lights can be set to turn on when the central locking is operated).
POSITION 1:
- Usually the audio system, unless it's an aftermarket system.
If the fuse breaks the second you turn the ignition to position 1 the audio system probably has faulty wiring.
POSITION 2:
If the fuse breaks the second you turn the ignition to position 2 one of these two components is the culprit:
- Seat belt reminder, oil level sensor.
Fasten all seat belts and try again with a new fuse.
If the fuse still breaks the oil level sensor is most likely the culprit.
If the fuse didn't break the seat belt reminder is the culprit. If so you can simply disconnect the seat belt reminder relay, ridding you of both your fuse problem and the annoying seat belt reminder. The relay is located behind the cover over the drivers feet (easily removed, just a couple of torx screws, no breakable interior clips).
The central locking relay and the alarm module are also found there, as well as some other electrical components.
The Data Link Connector is an unlikely culprit, but it's probably best if you unplugged it completely during testing.
If everything turns out ok with it disconnected you can test it at the end. (The Data Link Connector is the OBD II conncetor located by the coin holder, in front of the gearchange).
3answers
Cow boy alarm fitter came to fit alarm.When came to pick car up cenral locking did not work. he didnt no what he had done. So i had my car back with out paying 3 days later . I have now taken alarm of...
Try to check wires to the driverside central lock master motor. alarm installer probaly cut wires inorder to link the alarm to your cars central locking system.
Central lock master motor usually comes with 5 wires, two is the motor supply wire capable of reversing its polarity depending on lock or unlock request, the remaining 3 is just a swtich. One is ground and the two are negative request swtich for lock and unlock. If all fuses were good this moght be the problem, try also to check the outside fuses- in the hood. Good luck!
2answers
Escort 55 van...lighting problems
water ingress on top of fusebox above drivers footwell is common problem.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
