Question about Seagate 120GB 7200 rpm Ultra ATA/100 8-Mbyte IDE HD p/n ST3120026A (ST3120026AB) Hard Drive
Seagate SanMax 120GB external with fan noise
The internal fan of this SanMax, purchased April 2007, is making noise. Do I need to replace the fan, run it with the fan off, or replace the drive?
  • 22 Answers
It depends on the noise. It should be still under warranty. You should NEVER operate it without a fan as this is a safety hazard. If it is making a noise like a buzzsaw, it is most likely the bearings of the HD mechanism. If it is making a scraping noise, it's likely the fan. Make use of the warranty if/while you still can!
Posted on Nov 14, 2007
I bought my seagate free agent go in april of 2011 and registered it as well. I have all my important work layouts on this and the usb connector on the external hard drive broke off and now i cant connect...
First, since you purchased the product in 4/11, you should contact the manufacturer for a replacement housing for the hard drive. If that's unsuccessful (or if you don't have that much time), you can purchase an external docking station. Then remove the hard drive from it's case and insert it into the docking station.
Sep 14, 2011 | Seagate Momentus 5400.6 500GB SATA/300...
I was using seagate hardisk...after sometime it continously produces abnormal sound.I asked an expert and he said that my hardisk is dead.So i bought a new one.Now when i start my computer after some hours...
Possibly but if the noise is back again after replacing the disk, I would check into overheating. If you have access to an air compressor, blow out the case, fans, heatsinks, and power supply. Block the fan blades before cleaning fans as you do not want to over spin the fans which might damage the bearings.
Was the disk an external as your posting indicates? or an internal drive?
Jim
Preston Computer Services
www.prestoncomputerservice.com
May 31, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Do you have a Maxtor One Touch 120GB Users Manual available online?
Yes. Here you go - link.
To view this you'll need a pdf reader installed or use Google Chrome browser that has pdf reader built in.
If you need a pdf reader, you could try this one - http://www.foxitsoftware.com/pdf/reader/
Mar 15, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
How can you connect a seagate 250gb external hdd to a ps3 120gb
i have just bought a seagate external 1tb hdd to store more stuff on but it wont connect to my ps3 slim 120g what can i do
Nov 16, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Replacing HDD in ACER 2920Z
never use internal HDD without knowing. Use same old HDD and use external hard dsc now u brouught 320 sata use casing now
Jun 18, 2009 | Acer Aspire 3690-2900 Notebook
The connector of my seagate free agent 160gb is broken, can i bypass the connection with an other adaptor in the internal hard drive
Solution No1:
You'll need to take it apart desolder existing cable and solder a new one (standart you can get in any sho).
Note: If you'll mix up wires than you can damage your motherboard or hard drive itself.
Solution No2:
Take it apart, remove hard drive, buy a new 2.5" SATA Caddy and fit you hard drive to it.
Mar 11, 2009 | Seagate FreeAgent Go 120GB External USB...
Lost power supply
I think you might find this link most useful, from the Seagate Community Forums.
http://forums.seagate.com/stx/board/message?board.id=onetouch&message.id=1973
In short, others have had great difficulty buying Maxtor replacement power adapters, however you can buy a generic 12V, 3A DC power supply for $15-20 from a number of sources. Confirm your actual power requirements by referring to the product label on the drive itself.
Hope it helps,
Mike
Dec 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
SanMax portable drive suddenly, after 22 mths, not recognized by XP
may be partition table is mismounted,go to dos mode and run CHKDSK for your external drive .(press F8 after post and select dos mode)
ragards
prasanna
Dec 16, 2007 | Computers & Internet
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate 120GB 7200 rpm Ultra ATA/100 8-Mbyte IDE HD p/n ST3120026A (ST3120026AB) Hard Drive Logo
171 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
