Question about HP LaserJet 2200D Printer
Stuck on Red
Printer has constant red light to right of triangle and two green lights. Rebooted computer, rebooted printer, disconnected usb from printer and rebooted ... nothing. Sounds normal, however, lights don't go out and printer does not respond.
  • PETECHAU Dec 17, 2007
    MY RED LIGHT NEXT TO TRIANLGE IS CONSTANTLY LIT
    BUT DONT HAVE GREEN LIGHTS ON MY HP LASERJET 220D
    IVE ALREADY CHANGED THE TONER
    SO I DONT KNWO WHAT TO DO
  • 417 Answers
Normally mean fatal error on this machine you can hold the go button down for a couple of seconds and it might give you a secondary light sequence. Normally if the red light is on and nothing happens the most common fault is the fuser unit is not warming up.
You will have to replace the fuser unit, but this all depends on the second light sequence.
Thanks J
Posted on Jan 07, 2008
Check for the initialising state of the fuser if nor try replacing the fuser. this can be confirmed by second led pattern
Posted on Jan 09, 2008
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
Jan 18, 2013 | Canon PIXMA Office Equipment & Supplies
Ip4950 waste ink absorber
this is how to do it use xp
http://www.mediafire.com/?dbi16o3ovel1iyk
download the v3400 for free in link above it is 9,5mb ( there is a other file dont use it only the service mode tool v3400 )
follow this instructions and you will be fine
http://www.2manuals.com/product_info.php?products_id=1445
4. Run the Servicetools V3400.exe program.
5. Select the connected USB port number from USB PORT
6. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
7. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Dec 13, 2012 | Office Equipment & Supplies
HOW TO CLEAR INK ABSORBER FULL ON CANON IP4900?
Dec 09, 2012 | Canon Office Equipment & Supplies
How to reset waste ink full in canon pixma 4920
Dec 08, 2012 | Canon PIXMA iP3300 InkJet Photo Printer
Canon ip4950 error waste ink
hi caveman 68
Oct 06, 2012 | Canon Office Equipment & Supplies
Software to rest the canon pixma ip 4940 printer ink absorber full problem
i have able to reset ip 4940 but the problem is after switch off the printer it return to ink absorber full what can i do please
Sep 06, 2012 | Canon PIXMA iP4920
Canon ip4970 waste tank reset
Feb 11, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
HP LaserJet 2200D Printer Logo
588 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
