Question about Samsung HT-Q80 System
Noise at Startup of System
When I first turn on the system it makes a terrible buzzing noise as if a component inside is not engaging. After a minute or so it goes away, but it does this everytime you start it. Is there a fix for this problem, or is the system no good now?
Re: Noise at Startup of System - Samsung HT-Q80 System Home Theater Systems
Just replace the fan in the back
Posted on Nov 09, 2008
0 characters
3 Points
Model SA-AKX50. Why is it making a continual buzzing noise?
A low frequency buzzing sound is usually the result of a bad component in the power supply.
Dec 05, 2015 | Panasonic Home Theater Systems
I have extreem amount of noise between my tascam 2488 to computer based recording program , how can I delete the noise ?
What kind of noise is it? If it is hum or buzz, then you probably have a ground loop. If it is hiss, then you are picking up noise in the cable, most likely. For ground loops, see:
As for the cable, the cheap ones with the red and gray plastic ,olded ends can get noisy after awhile as the shielding is rather fragile. Cracling type noises are usually cable related as well.
Jul 30, 2014 | Tascam 2488 Portastudio Multitrack...
Speakers make a buzzing noise and then cut out after a few minutes it happens again. speakers are wired correctly have no idea what the problem is
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Jan 05, 2011 | RCA RT2770 Theater System
It has this terrible hiss/chatting noise from both channels even during low volume!” The noise(almost like a howling) come out when the unit become warm
check the power supply inside ur amplifier may be there is some dry soldering. or the tone control side have some problem. check tone ics +and - supply rail, it should be 15v at pin 8 and 4. also check the input selector ic for any dry soldering.
Dec 22, 2010 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Cliking / buzzing noise
there is a known problem with the amp board going bad. contact kef america and they should do repair under manufacurer extended warranty. if not the flat rate repair is around 250. if you compain enough they should do fix for free. hope that helps.
Jun 05, 2009 | KEF Audio KIT100 System
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Rca home theater system reciever makes noise when turn on
is it a humming noise, or a high pitch noise, and is coming from the speakers or the receiver?
Jul 21, 2008 | Home Theater Systems
Samsung HT-Q80 System Logo
255 people viewed this question
Top Samsung Home Theater Systems Experts
Electro Med Services...
Brandon M.
Level 1 Expert
Are you a Samsung Home Theater System Expert? Answer questions, earn points and help others
