Question about Maytag MAV7600 Top Load Washer
Maytag mav7600 agitator works and don't
Agitator wouldn't work when water filled put new timer in and it worked for a few days then stoped again, Pulled plug of timer reinserted it and it worked again been having this problem since new timer was put in, If wife turns to spin cycle and then back to start it somtimes works again. Any help will be greatly appreciated.. Can it be another bad timer.. also sprayed contact cleaner in connection.. worked for a few days and then started with same problem
Ps hope this is right way to ask.
  • 1 more comment
  • guysr1 Nov 17, 2007
    Did not quite understand did you mean on the timer itself ? or the harness from the washer looked and didn't notice any difference space on the pins thanks for the help but still at a loss. Seems to be somthing in wiring or another bad timer like I said sprayed it with contact cleaner but still have problem .
    Thanks again for you help..
  • Anonymous Nov 21, 2007
    All I can say is basicly the same works at times don't at others pull plug out of timer put it back and it works.. wife spins it around to spin and when it starts she puts it back to start..
  • guysr1 Nov 21, 2007
    forgot to sign in so here it is again same problem works at times don't at others wife spins to spin cycle and when agitator starts put it back to start and it works. other then that the last few times all I did was pull plug to timer reinsert it and it worked.. thank for any help
  • 248 Answers
Look at timer plug on harness for pins that are sticking out from side of timer plug, away from timer. See if they are all in the same amount. Sometimes one can work its way out so it won't make a good contact. Push in to plug if you find one.
Posted on Nov 15, 2007
  • Gerald Griffin
    Gerald Griffin Nov 18, 2007
    You have to check on the plug itself, not timer.
My washer does nothing when you put it in the rinse cycle however it does fill with water. I believe the problem is the timer switch. can you confirm this issue
Not so? If it does not go into agitation? You may have a bad water pressure switch which sends signal to start agitation. but also can have bad cam dogs in agitator which do not engage agitator? a bad door switch will not allow agitation or spin on some appliances. And lastly yes u may have a bad timer wheres points have fused? can check most of these with a multi meter
Feb 05, 2015 | Maytag Washing Machines
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mav7600 won't agitate
It is your Transmission. Mine did the EXACT same thing just a couple days after your post. If you want some troubleshooting advice, part numbers, where I bought my parts, or advice on disassembly/reassembly, I will be glad to help. The truth is, I already wrote a detailed answer to your problem and before I posted it I read the "Terms of Use" page, and when I went back to the "solutions" page, everything I wrote was gone. So, if you want it, let me know and I will try again.
Feb 21, 2008 | Maytag MAV7600 Top Load Washer
Maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Jan 26, 2008 | Maytag MAV7600 Top Load Washer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Dont worry by the time you read this it will probably already start working again. There is a Auto Reset Thermal Overload Switch on the motor that shuts it down when its pulling too much amperage. Its not good for them but they are usually fine. Just advise your wife its hard on your particiular design washer to be overloaded.
Nov 25, 2007 | Maytag MAV7600 Top Load Washer
The timer itself is bad, replace and wala! Timer Part Number: PT756240 Made by MAYTAG $70.22 + S&H
Sep 16, 2007 | Maytag MAV7600 Top Load Washer
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. back.
Jan 26, 2007 | Maytag MAV7600 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
