Samsung Galaxy Centura Android Prepaid Phone with 600 Minutes and Triple Minutes Tracfone Logo
A
Anonymous Posted on May 04, 2015
How do I increase the number of times the phone rings before it goes to voicemail
Lisa Silver
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 56 Answers
  • Posted on May 04, 2015
Lisa Silver
Expert
Level 2:
New Friend:
Night Owl:
Answers
56
Questions
5
Helped
9981
Points
251
Turn your voicemail off ? thru setttings then call.? or try this
type this into your phone
**61*101**30#
press call
this will extend the ringtime from the default of 15 seconds to 30 seconds
Change How Long Your Phone Rings Before Sending Calls to Voicemail
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
1helpful
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Our phone only rings 4 times before it goes to voicemail.
Depending on your phone ,but you should be able to adjust it in your setting and that is in your phone menue
3helpful
2answers
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 • Cell Phones
Nokia 1100 increase no. of rings before going into voicemail
you can not do that only your provider can assign the number of rings before going to VM...so contact them and have them do that for you....
Dec 15, 2008 • Nokia 1100
How do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
1helpful
Change the number of rings - Samsung D500
This is a network related setting. Do the following.
from your home screen, type "* 61 * (voice mail access
number) ** (time in multiples of 5 ) #" and then press SEND. For
example, if my voicemail
access number is 404-555-1212 and I want it to ring for 20 seconds
before forwarding to
voicemail, I would type: *61*14045551212**20#
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
