Question about Sony KP-53S65 53" Rear Projection Television
Blue Ghost The picture has blue ghosts. I have tried to adjust the convergence but it will not adjust to the left. It will adjust up and down and to the right but it will not move back to the center. Please help. Thanks
  • sharebear911 Mar 14, 2008
    I get a blue bowed ghost appearing from the top right and left of the screen. I bought the 42 inch Samsung projection TV off warrenty and had it since Christmas and now its like this. What can I do to fix it? Its Madel Number HCP 4363 WX/XAA.... serial number 31EX501436M..... could it be the convergance... if so, what is a convergence and how do I get one and install it. I have a computer suddering gun and some computer experience.... Please help a single parent single income family get their only Christmas present back... its been I tough year... thank you for anything you can help me with. ...
  • Sony Master
  • 8,617 Answers
You need new convergence ICs . They cost about 10.00 each you will need two. They are located on a large aluminum heat sink with an STK number stamped on them. They will have to be soldered in. If you can solder you will be able to do this repair yourself. Let me know if you need ay additional Info.
Posted on Jan 24, 2008
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
Severe Ghost.
Mitsubishi has been known for having bad solder connections on their Convergence ICs from the factory. If you are tech savy, and don't mind doing some soldering, follow these instructions:
Unplug set, remove the back cover, find the convergence board (should be labeled, if not it is the long narrow board usually on top or side), find the convergence ICs on the heatsinks and resolder all the pins and ground. This should fix your problem.
Jan 09, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence problem, blue ghosts
you need to replace both convergence ICs they are both STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Color is off
Center the controls as best you can, disregarding the pix for the moment. Then, do a mechanical setup, getting the alignment as close as you can. Now, perform the electrical setup and see what you get. If you can't get it any closer, you'll have to address the convergence probem that we suspected you have...accordianman
Feb 19, 2008 | Zenith R45W47 45" Rear Projection HDTV
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Your Convergence ICs need to be replaced. If you need anything further let me know.
Jan 23, 2008 | Zenith R40W46 40" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
