Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic CT-36HL44 I have the above model. The power light comes on, but no picture or audio. There is an orange wire that looks like it connect to the L board (L11 or L12?), but I'm not sure where. Could you help or send me a picture of an L board (one on the back of the CRT)? Thanks!
  • 126 Answers
Is the orange wire a plug in or is it broke off the crt board if so solder back together
Posted on Feb 17, 2008
Model CT-36HX42 - power to set, no power, no picture, no sound. Is there a fuse or reset?
The main power regulator section has to be troubleshooted. It is a skilled work and not a user repairable one.
Aug 26, 2012 | Panasonic CT-36HX42 36" TV
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
TV was working one second and we turned it off.
press the key setup or menu and select restore by default,
if no solved your problem, you need get support technical panasonic
Mar 07, 2010 | Panasonic CT-36HL44 36" TV
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Picture on and off
these arent easy fixes,have them serviced
May 19, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Hello, My Panasonic ct-36HL44 won't turn on. It's complestely dead. Yesterday and for the last 4 years---its been perfect, completely reliable. What happened? Is there a fuse inside the chassis and can I...
I had the exact same problem with this model a few months ago. Repairman came out to my house and told me that Panasonic is well aware of the problem but never issued a recall on it. He then charged me $150 to take off the back of the tv and replace a blown fuse with another fuse with a slightly higher voltage rating. Took him all of 5 minutes. He took off back of tv and the fuse is located, if you are standing at the back of the tv, on the bottom in the left hand corner. You can't miss it. I wish I could tell you which fuse he put in but I didnt see it. Sorry. Try it for yourself and you might be able to save $149.50, b/c I doubt that fuse cost much more then 50 cents. Good luck.
Mario in NY.
Dec 09, 2008 | Panasonic CT-36HL42 36" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
