Question about Pitco Frialator SG14 Deep Fryer
I replaced the thermocoupler still not staying lit.
I replaced the thermocoupler but the pilot will only stay lit when the water heater needs to turn on. after it heats the waer it will go out again.
  • saole702 Feb 25, 2009
    changed thermocoup and cleaned gas line to pilot after water heated pilot goes out gas lines are snug
  • Anonymous Mar 18, 2014
    replaced a thermocouple now pilot light not staying lit
I understand it that once the main burners go off, after the thermostat is satisfied (water heated) the pilot goes out too at the same time.
Make super sure the top of the t-couple is getting hit directly by the pilot flame. You may need to adjust the t-couples position, or even clean the pilot assemblies oriface. Double checking the connection of the coax cable at the gas valve would be a good idea too. tight but not super tight.
Posted on Jan 15, 2008
I have an old whirlpool gas water heater and the pilot will not stay lit.
Suspects include bad thermocouple, thermocouple slipped down and not in pilot flame, dirty combustion parts and pilot tube, dirty air intake, backdraft caused by other vent fans pulling air down water heater vent, water dripping down vent because of poor venting, air in gas line, low gas pressure, bad gas control valve, hot attic environment, tight house not allowing enough air:
Replace thermocouple:
http://www.youtube.com/watch?v=v0aBPsNg6vo
http://www.youtube.com/watch?v=xGQngzqrIEE&NR=1
Troubleshoot pilot:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Clean combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 24, 2011 | Water Heaters
Pilot lite does not lit please advise what to do.the burner stays on if lit directly with open flame.is this dangerous.
What you describe is typically caused by a faulty thermocouple. The thermocouple senses the heat from the pilot light and TURNS OFF the pilot when it no longer senses the heat.
When the thermocouple turns off the pilot, it's not necessarily dangerous, but the water heater won't turn on without help.
Mar 23, 2011 | Water Heaters
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Piloit won't stay lit.
I would check to make sure thermocouple is in proper position in pilot flame. If so and pilot won't stay lit I would replace thermocouple. Thanks
Nov 12, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Feb 23, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot will not stay lit and heater will not light
thermocouple probablly bad, is the flame covering the thermocouple.
the flame has to hit top portion of thermocouple to work correctlly.
Feb 14, 2010 | Endless Summer (GA200209) Stainless Steel...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Pitco Frialator SG14 Deep Fryer Logo
296 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
