Replacement is a steel conn. BES-830154, when I replaced it it still leaks badly. Seems as though the clip slot is too wide creating too much play. almost seem like there should be an o ring between the line and conn seat. any suggestions?
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
SOURCE: Can't get tight fit between basket & steam ring
the proper replacement steam ring has an up-side & down side. the brew-head plate must be installed with the grooved side facing up; the steam ring has a groove in one side that fits over the top up the brew-head plate...does this solve the problem? if not, you may have the wrong steam ring/the brewhead plate may be installed incorrectly...oh, nov of 08...i seriously hope you've figured this out already. if not, you don't happen to still have machine in your possession, do you? if so, i'll buy it for $5.
SOURCE: I have a bad O ring which causes pressure to be lost
Where can I order spare or replacement parts?
Toll Free Phone Number: 1-866-BREVILLE (1-866-273-8455) 8AM to 5PM PST
Email: [email protected]
Or you could try a few of the San Diego sellers -
http://www.brevilleusa.com/locator/search.jsp?head=0&submit=1&zipCode=92121&radius=5
SOURCE: My Breville Venezia Espresso machine leaks once in
Sounds like the brew solenoid is leaking.
SOURCE: Breville espresso machine BES 820XL has broken
It looks like they generally have the units shipped to them for repairs. Here is the Breville support page for your model:
http://brevilleusasupport.com/product/bes820xl?lm_search=bes820XL
If your machine or one of its parts qualifies for replacement under Warranty (please check Terms of Warranty section above), please contact our Customer Service Center: We will send you a pre-paid FedEx label via email so you can ship the product to us for free. Once the unit has been received, we immediately ship the replacement. The whole procedure could take as little as three days (about seven days if you're on the East Coast). If your product doesn't qualify for replacement under Warranty, you can still buy replacement parts or have your machine repaired by one of our Service Centers. Please contact us for information: Hope this helps.
I've copied the relevant portion for your convenience:
Warranty Process
Toll Free Phone Number: 1-866-BREVILLE (1-866-273-8455) 8am to 5pm Pacific Time
Out of warranty
Use a continuity tester or multitester to test for continuity.
Set the multitester to the ohms setting X1. Touch one probe to each
terminal. A reading of infinity indicates a bad solenoid that must be
replaced. Different brands and models will have various measurements,
but the valve should show some resistance if it is functioning properly.
Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer
is off, then the valve itself is the problem. Debris may be preventing
the valve from closing. If the valve cannot be cleaned, it will have to
be replaced.
The valve can also fail mechanically. So even if it passes the
electrical test, it may still require replacement. If you have ruled out
all other possibilities, go ahead and replace the valve.
Click here to order replacement parts.
Page 2 of 2
Previous Page
