Question about Symbol Cobra LS1902 Handheld
Using scanner for inventory only
I have an 'LS1902T' scanner by SYMBOL circa2003.
My windows XP recognizes it and it functions. is there a driver I could buy or download to use this scanner simply to read raw data into a file, or spreadsheet, for inventory. This would be for my own personal use as My Boss doesn't want the expense of all the accompaniing equiptment, IT would just make my record keeping a little easier. Thanx.
Hans Schmitt, Commerce Office Furniture Liquidators.
  • 4 Answers
Scanner is adding the characters }w before bracodes.
Do you have a configuration manual book?
I think you can go to factory settings from there.
Mar 18, 2014 | Symbol Lot 4 Ls1902t-1000 Barcode Scanners
Symbol ls1902t-1000 scans extra characters when scanning a barcode
Download the quick start guide from and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Oct 29, 2012 | Symbol LS1902T-1000 Handheld Laser Barcode...
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
This unit is only supported by Windows 2000 or Windows XP environments.
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Is there a driver for barcode scanner i am holding Model No - LS1902T-1000 company - symbol tech inc. hotsville n.y.
The barcode scanners are usually using ans Standard PS/2 or USB interface in the same way as keyboard, therefore you dont need an driver.
You would probably need to setup the barcode scanner according to the used connection/interface.
Here is the manual for yur scanner
Jul 08, 2010 | Symbol LS2208 Handheld
Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Aug 11, 2008 | Symbol LS2208 Handheld
Need instructions
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at
Jan 14, 2008 | Symbol LS1902T Handheld
Symbol Cobra LS1902 Handheld Logo
326 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
