Question about Malibu Boats Intermatic Cl9 20-wMalibu Low Voltage Cast Metal Halogen Landscape
My low voltage cable for Malibu landscape lighting is hot to the touch. Is that how it should be?
  • Ken Green
    Ken Green Apr 22, 2016
    Hi sherry , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
I bought a Malibu 300W low voltage landscape transformer to replace a 200W unit that stopped working. It worked for 1 week, then stopped .. the reset **** doen't work. The LED works, I do see a...
I don't know if it burned out, but something is not right.
Malibu products come with 1-5 year warranty.
New product that stopped working should be exchanged for full replacement at place of purchase, except possibly the auction sites.
New Malibu product should work for many years.
Be sure to match bulb voltage with transformer voltage to avoid possible problems.
Mismatched bulb and transformer wattage should not affect a timer in short period such as 1 week.
Another thing to check is outlet polarity. Use circuit analyzer from home center to check outlet.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 20, 2011 | Intermatic Malibu 300W Power Pack...
Unit was working fine today. I was repairing some connections in the landscape lighting cables and checking each connection after completing it. At one point, I was testing the lighting and got nothing. ...
The power pack should make a humming sound when ON
1) Maybe power to the plug is off
Plug hair dryer into plug and see if it works
Check your GFCI resets in bathroom and kitchen
Check breaker in box
2) Maybe time of day needs to be set
Unplug power pack > plug back in > set on-off trippers
Rotate dial counterclockwise to present time
Then rotate dial two complete revolutions and return to present time
Malibu homepage
Malibu manuals
How to select power pack: # of lights and length of wire
Oct 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
May 09, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu landscape transformer
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Oct 29, 2008 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu Boats Intermatic Cl9 20-wMalibu Low Voltage Cast Metal Halogen Landscape Logo
559 people viewed this question
Top Malibu Boats Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Malibu Boats Electrical Supply Expert? Answer questions, earn points and help others
