Question about Malibu ML300RTW - Low Voltage Power Pack -300 Watt - With Timer and Ground
Removed 2 landscape fixtures by cutting leeds @ piercing connector since they're impossible to remove. Now remaining lights are dim. Why?
All light worked fine before
  • Malibu Master
  • 5,245 Answers
Only one bright light works even after replacing the bulb. What could be the reasons for this? All other lights work fine.
it sounds like you have an open curcuit in the b+ wire. the can be at the back of the conector/pigtail.
May 22, 2012 | 1994 Nissan Maxima
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
1998 Ford Taurus Dash (Console) and Backlights are not Working
If the 15 amp fuse #20 in under the hood is good, suspect the headlight switch is bad.
see diagram at link below.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=62901
Aug 15, 2017 | 1998 Ford Taurus
2003 gmc envoy xl brake lights dont work
theres usually a pressure switch behind the brake pedal, sometimes the plastic hex nut rattles loose and you have to retighten it.
Apr 12, 2009 | 2000 GMC Sierra
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Lower brake lights dont work,third light does
Turn signal switch 95% of t he time. Try to work your hazards, if it stuck at all will also cause this.
Feb 10, 2009 | 1998 Chevrolet Blazer
1995 Mercury Tracer Rear lights not working
does the Center brake light work ? I think your looking at replacing the brake light switch !
Dec 19, 2008 | 1995 Mercury Tracer
Malibu ML300RTW - Low Voltage Power Pack -300 Watt - With Timer and Ground Logo
202 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
