Question about Oreck Air Instinct 200 True HEPA Air Purifier
The mood light stays on, how can I fix it?
Mood light won't turn off.
  • 7 Answers
I do not know if the answer will be here but maybe it will.
http://www.oreck.com/airinstinct-200-air-purifier/544.html?start=1&cgid=air-purifiers
Posted on Jun 03, 2015
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Jul 22, 2011 | Vornado AQS35 Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
My ionic breeze s1867 turns on and off will not stay on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
Mar 02, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Sharper Image Midi S1853 / NO BREEZE
Jan 12, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Cleaning light stays on
Jan 18, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Power light not coming staying on...
pull the cells out and run the filter without them. If the light stays solid then you most likely have a simple short in one of the cells. Install one cell at a time, push it all the way back, close the door, turn on the fan. IF the light stays solid, that cell is fine. If the light flickers or goes out, the most common cause is a bent fin.
Look at the cells and see if any cells are touching or are too close, this will cause your problem.. Simply bend the cells to get even spacing and you should be ok.
Jul 15, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Hybrid gp problem
You have to locate the "blade" that is causing a short (usually can see it sparking; if not, reset it (turn it off then on) in a dark room and locate the problem area (this is how I figured it out).  If you can locate the offending "blade", simply tear it out of the base where the spark is occurring, fold it back against itself so the metal does not contact anything other than itself (and is no longer contacting the base where the sparks occurred).
This fixed my unit (I was just about to throw it out when I tried this solution).
Jan 11, 2008 | Sharper Image Hybrid GP (SI724) Air...
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Oreck Air Instinct 200 True HEPA Air Purifier Logo
254 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
