Question about AKG Perception Wireless Instrument Set (SR45 PT45 MKG L 14 cable)
After 6 months got good service, unit is sending a garbled signal..it is not a PA problem
    Top Expert:
  • AKG Master
  • 3,107 Answers
Most likely a battery issues, but also try moving the receiver to even a slightly different location to see if it affects the signal,
Posted on May 03, 2015
    Master:
  • 371 Answers
Low battery?
Acoustic b600h
Relay?? I've never seen a guitar or bass amp with "speaker protection relays"...usually they're either on or off. Check the simple stuff 1st...is speaker cable from head to cabinet and/or the input cable from bass to the amp good? Check the "Direct Out" for a line level signal (must be connected to a PA or other amplifier) as this is your preamp out signal. Also, plug a shielded cable from "Effects Send" to "Effects Return"...this will verify "effects" loop issues if any. Lastly, vibration test...use a clenched fist across the top, sides and bottom of wood cabinet to lightly "jar" the internal circuits. If it starts working even for an instant, I would suspect intermittent connection inside.
Jul 30, 2014 | Acoustic B600h 600W Bass Head And B115neo...
Monitor mix of x2442usb
Hi Mark, I mailed Behringer and they sent me details of how to do it. If you mail me at seanflynn40@talktalk.net I'll forward it on to you. It looks really complicated to get a stereo signal through but I just use mono signal and its simple and works really well
Feb 27, 2012 | Behringer Xenyx X2442USB / Harbinger...
Driverack pa plus sends this message WAITING FOR FLASH DOWNLOAD V. 0.109. i tried hard and soft reset but nothing happens, is there a solution?
The unit has been put into the mode to reload the operating system. You need to connect it up and load it with fresh download of the system. You can probably download the firmware from the manufacturer's site in their support section. There may be no other way to restore it. Be careful as any corruption during a flash download can be fatal requiring return to the manufacturer for reloading. Find the firmware for your unit here:
http://www.dbxpro.com/Software.php
Follow the directions for instalation TO THE LETTER !!! Read twice before doing !!!!
Jul 21, 2011 | DBX Professional Products DBX Driverack PA...
Hello My Harbinger APS15 has a constant clip light lit. We can't get any output from the unit and it's just a couple of months old.
Likely the power amp has shorted to one rail... DO NOT attempt to use it as it could be sending high current through the speaker causing damage. Age of the unit doesn't have much to do with it. Take it in for repair. Unless you are electronically adept and can get a schematic this is not DIY.
Apr 17, 2011 | Behringer Xenyx X2442USB / Harbinger...
I plug two roland pk-5a to have 1 octave above the other one but the problem is I can't play in the BASS MODE or MONO MODE with the HOLD function on and stop the note I play on one unit when i play a note...
If you have two MIDI sources that you send on the same MIDI or to the same MIDI sound generator you have to use a "MIDI MERGER" or you will get notes stuck on. A MIDI merger assembles complete messages before sending them to their destination. Without it, the messages are mixed which makes them garbled.
Mar 24, 2011 | Roland PK5A MIDI Controller
I have an XR8600 - I am using it without Monitors. The Main/Monitor Send is sending a stonger signal to one speaker than the Main/Main send is to the other. have checked leads and speakers and know it has...
Check the pan cotrols are at 12 o;clock.
Verify your speakers are identical and speaker cord length is about the same.
Swap speakers to make sure it is not the speaker,
Feb 17, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
SWR WorkingPro 400 watt head - no sound, Preamp Clip red LED is continually lit, Limiter green LED continually lit - fuse is perfect. It worked for a few minutes, then just stopped.
Since the PA clip is not lit, the problem seems to be up front...
First thing is to look for a bad cable as a broken ground could be putting hum at a clipping level. First thing, test this by unplugging all inputs. If the clipping light goes out, then you have bad cables or a ground loop.
Try sending a line level signal into "Effects return" to test if the power amps are OK.
If the clip light is still on, turn all gain controls down to minimum. If light is still on then take unit for servicing.
May 31, 2010 | SWR WorkingPro 15 200 Watt 1x15" Bass...
Other speakers, with input/output, were attached to Fender Passport in the send and return ports. There was a loud squeal and not the Passport does not work.
The send and return jacks are only meant to be used with external units such as reverb, effects etc. These units use a low signal voltage. You have probably dam,aged the internal circuitry. You will have to take the P.A. to a repair center that has experience with Fender products. Your warrantee if it is still in effect will not cover the repair. Soory to give you bad news.
Nov 21, 2009 | Fender Passport Deluxe 500watt Sound...
AKG Perception Wireless Instrument Set (SR45 PT45 MKG L 14 cable) Logo
48 people viewed this question
Top AKG Music Experts
Vito Vacirca Jr.
Are you an AKG Music Expert? Answer questions, earn points and help others
