Question about Refrigerators
Not cooling door not sealing no suction in cab
  • Refrigerators Master
  • 5,323 Answers
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Posted on May 09, 2015
Door lost suction so replaced gasket still no suction
you replaced the door seal
did you clean the surface area of the fridge door opening
try
smear vasaline sparingly all around the seal surface
if no better
could be a hinge problem
or
the system need a thermostat replacement or regas
May 12, 2016 | Refrigerators
Door not creating suction when door closes
the door may need adjusting
cut an place a strip of paper between the seal and the fridge and close the door
if the paper pulls out easily then the seal is not touching fridge
The suction is created when the warm air from the room that gets into the fridge when the door is opened is cooled down and occupies less space hence the lower pressure and the vacuum forms
I have a frigaire ice box with french doors the freezer will not stay closed
(1) make sure nothing is protruding out ward toward doors, (2) make sure the sealing area is clean along with the seal. These doors do not have a latch, has suction seals. now when you close it PUSH in-ward on door to cause a suction seal..(.a long ham bone could be hindering it.)
Feb 09, 2015 | Refrigerators
How do I reset my 601R refridge so the suction seal comes on?
I assume your unit is cooling correctly since the following explanation is predicated on a properly working refrigerator.
There is no "suction seal" that comes on with your refrigerator, rather this the effect from the closing of the door and the rapid cooling of the warmer air (that entered with the door open) which causes a contraction that is the vacuum you feel. This will only last for a short time as the built-in venting (usually via the drain) will allow the low pressure to balance so the door opens normally. If this has ceased to occur it indicates there is an air leak somewhere which prevents the vacuum from forming. Replacing door gaskets can be tricky so be certain the door closes and seals all the way around. Using a dollar bill (or similar slip of paper), insert the bill between the door and cabinet, close the door on it and then gently pull the bill out. You should feel a slight resistance and have to tug to slide the bill out. Repeat this every few inches all the way around the door to locate any spots where the contact is not as firm. Typically this can happen on the hinge side, especially near the corners.
You might have a hinge problem, a warped door or some other problem that keeps the door from closing fully.
Jun 23, 2014 | Sub-Zero 601R
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
Why is or fridge leaking water out the bottom. Bottom mount fridge, checked the water try in the back, no cracks, no leaking, Twice in four days days it leaks water on the floor. No problems cooling,...
I've seen this occur when the refrigerator door is getting closed fully Either a food item is preventing complete closure, (though it may look closed) or a seal is failing. Check the seals by pulling a dollar bill out from in between the seals. If it doesn't catch make sure the seals around the doors are ingood shape and clean.You can also use a heat gun to warm -up the seal and get to expand so you get a good suction
Oct 15, 2010 | Kenmore Refrigerators
Suction of freezer door
No, that perceived suction effect is the magnetic door seals 'grabbing" onto the fridge cabinet and pulling the door(s) shut firmly and securely.
Typically as the fridge gets older, you'll need to clean off both the fridge cabinet edges and the door seals to maintain a proper seal, which is essential to keeping the fridge operating properly.
Hopefully you find this Very Helpful and best regards!
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
Aug 11, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
Fresh food door has poor suction
I don't know of any unit that creates suction. Most are magnetic. The seal itself has a magnetic strip molded into it . These are man made and deteriorate over time. If it is not holding the door closed it probably needs to be replaced. See if it has any magnetic ability left by placing a knife up next to it. It should pull the knife blade to it..Also the vinyl covering gets hard with age and does not bend to seal as easily. These two factors together can lead to sealing problems. This leads to frost accumulation around the door and poor cooling if the seal is bad enough.....Let me know...
Dec 27, 2007 | Sub-Zero 632 / S
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
