Question about Kodak ESP 5250 All-in-One Printer
As new cartridges new printhead will not print white sheet
  • 398 Answers
Please check that you have removed the sealing tape on the new print cartridge. Believe it or not this is a very common mistake that people make when inserting a new print cartridge. The next common issue is to make sure that the cartridge you bought is actually made for your model machine!
Good Luck!
Rich Lilja
Posted on May 03, 2015
Has new cartridges new printhead will not print, only blank white sheet comes out of printer
If your cartridges and print head are new and printer won't print, you have a serious problem and if you don't have the technical knowledge, I fear you can'r repair it yourself, so you should take your ptinter to service
May 04, 2015 | Kodak ESP 5250 All-in-One Printer
When I try to print a black and white document it started printing in reverse (black prints white; white prints black). If I print a black & white photo it looks like a negative. I tried resetting the...
Kindly reseat the cartridges 2 time and then close the access door .Clcik on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning" Print a demo sheet after the cleaning process has been completed. If ur issue persists,Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost. Printhead is the part which takes the ink out from the cartridges.Probably the printhead of the printer has gone bad.
Nov 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
It prints right on black and white but prints blue in color
Kindly reseat the cartridges 2 times and then close the access door .Click on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning"
Print a demo sheet after the cleaning process has been completed. If ur issue persists, Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost.
Printhead is the part which takes the ink out from the cartridges. Probably the printhead of the printer has gone bad..
Nov 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I've changed the black ink cartridge but it won't print in black
Sounds like there is a problem with your printhead. You need to clean it using the printer itself (menu -- clean printhead -- deep clean). If this does not work, go to kodak.com/go/itg to get your printhead replaced, free of charge.
Dec 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodok easyshare 5300 printer/scanner
Print out a demo sheet. Press copy and photo at the same time. If the black isn't printing on this demo sheet, (the eyes on the two kids at the top are all white), you need a new printhead. Your's is probably clogged. contact kodak tech support. 18004216699. Option 1
Oct 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak Easy Share 5100 will not print after I changed black cartridge
Press copy and photo at the same time and print a demo sheet. Look at the eyes of the two kids in the picture, if they look like zombies, your printhead is clogged. try cleaning the printhead and print the demo again. If it's the same, you need a new printhead. Call Kodak.
Oct 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink cartridge
You all need a new printhead. If the eyes on the demo sheet (copy and photo at the same time) are coming out all white and they look like zombies the black text isn't working properly. Try cleaning the printhead. If that doesn't work, call kodak, you need a new printhead.
Sep 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 printer
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black won't print
will print blank? try to do this, remove the cartridge and the printhead, put it back again. perform a deep clean by press menu>clean printhead>deep clean
print a demo sheet by pressing menu>print demo sheet
if it fails then contact kodak..
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 5250 All-in-One Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
