Question about Cub Cadet Garden
Cub cadet rider, white smoke, oil on spark plugs........help!!
  • Jo Porter
    Jo Porter May 03, 2015
    Thank you. But, I hadn't added oil or touched anything. It ran fine two days ago. I thought I ran out of gas, but after I filled it up it just started and about 5 seconds later it died. Also lots of smoke, white blue. I cleaned the air filter and checked the oil which was fine. Nothing.
    Master:
  • 426 Answers
You may have oil leaking by the rings, try some oil treatment such as Seafoam or Marvel Mystery Oil. If the rings just have carbon build up then it will clean it out and allow the rings to seal correctly
Posted on May 03, 2015
  • 948 Answers
Not to panic... the oil should burn off. It will just be a little embarrassing to have all that smell and white smoke until it does! However, the real question is, how did oil get on the spark plugs in the first place? If you spilled some oil on it, don't worry. If you left the oil filler open, make sure you check your oil level and close it. If you overfilled the oil level in your mower, drain some of the oil out.
  • 1 more comment
  • Rhonda Webster
    Rhonda Webster May 03, 2015
    Try removing the spark plug wire from the spark plug, then take the spark plug out by unscrewing it with a deep well socket, then clean out the oil from the hole with gas, dry it well, pull string or crank the engine to spit out the rest, put it all back together and see if that works.
  • Jo Porter
    Ok, I can do that. But I'm concerned about all the smoke that came out!
  • Rhonda Webster
    You said there was "oil on the spark plugs". When oil is on a hot engine it burns and makes white smoke. Don't be afraid. This is NOT a danger to your mower. There IS danger is if you run a mower WITHOUT enough oil.
Going to try this again, cub cadet rider mower leaking oil into air filter compartment, it's a 2135 with a 13 HP Command OHV motor
Sounds like a crankcase ventilator is plugged up. It serves the same purpose as a pcv valve on automobile.
May 22, 2017 | Cub Cadet Garden
Cub cadet rider mower oil leak
The crankcase breather may be partially obstructed but in most cases I see is the oil is a little over the full mark. It's better to have it a little low and never good to be over full. Hope this will help ya
May 21, 2017 | Cub Cadet Garden
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
What does white smoke coming from a cub cadet lawn mower mean
Most likely the valve seals or the rings are bad and the engine is burning oil.
Oct 06, 2014 | Cub Cadet Garden
Blowing white smoke
Either the valve in the breather is not working properley and causing a pressure rather than a vacume in the crankcase, or the piron rings or cylinder bore are worn.
May 28, 2013 | Cub Cadet Garden
White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
Aug 07, 2012 | Cub Cadet Garden
The oil was low in my Cub Cadet SLT 1550 so i filled it up, and after about 5 minutes the engine started smoking blue, smelled like oil and after a few seconds it turned really cloudy white
remove the spark plug and try and crank it over see if oil spits out you might have dumped it in to fast and it went threw the breather
Jul 10, 2012 | Garden
I have a cub cadet with a kohler command series 16 engine..It runs rough,oil gets on the spark plug and smokes a little what is wrong with it?
This usually means that is's been overfilled with oil, or the engine has been tipped enough for oil to run into the cylinder. Drain oil if it's above the line at all, and the problem will go away once the oil's burned out of the cylinder.
Mar 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have an early 90's cub cadet rider and it was over filled with oil. Now it smokes and blows oil out the exhaust. Could over filling it cause this? If not are there any common causes of blowing oil
Yes, over filling can cause this. The fix for this is to put the oil level back to normal, and run your machine normally, until the oil residue burns back off. Some "side effects" may be fouling spark plugs and occasionally residue build up in the muffler, so, keep this in mind. Normally, though, everything goes back to normal. It's better to run the machine for a while than starting and stopping it, to allow the machine to get up to operating temperature and clean out the exhaust system.
Best regards, --W/D-- please feel free to rate this solution.
Jul 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
124 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
