Question about Garden
The in-tank screen or sock is badly deteriorated and needs to be replaced. Is there a better option than the factory plastic/nylon screen?
  • 991 Answers
Nothing comes to mind other than fitting a inline filter between the tank and carb.
Posted on May 03, 2015
IS THERE A FILTER INSIDE THE TANK'S OPENING THAT MAY NEED REPLACING YUKON 2008
There is a filter at the inlet to the fuel pump inside the fuel tank, it is called a filter sock and it is made of fine mesh Nylon, it never needs replacing unless the fuel pump module is serviced. The Mesh stops all particles that will not pass through the fuel injector nozzles. It would be better to post what kind of problem you are having with the truck.
Apr 26, 2017 | Cars & Trucks
Can i replace only fuel filter of fuel pump with sending unit
Not sure why you would want to do this, but yes, most in-tank pumps have a replaceable "sock". 1 What are you working on? 2 Do you have to remove the tank to get to pump? 3 If your tank is so dirty that you need to replace the sock, better clean the tank out well.
Aug 07, 2015 | Cars & Trucks
I now have 2 H233H monitors that both have the same Problem. The cheap power switch has failed because the plastic ears have broken off of the button on both of them. Is there some kind of a fix for this?...
I took my soldering iron and melted nylon-plastic to the plastic (nylon) ears and plastic button which is also nylon. I now have a permanent and stronger plastic weld than what was made at the factory.
Repair shop wanted $125 dollars. I fixed it with weed-eater nylon string and soldering iron. Start at button first, after having a small glob of melted nylon on tip of iron. Then spread it to plastic ears, all the way back to the spot where ears attach to black trim piece. Good luck
Mar 26, 2011 | Acer H233H bmid Monitor
Where is the fuel filter located on a 2001 Mazda Protege 2.0 LX?
A 2001 Mazda Protege (actually, all models from 1999-2003 including the DX, LX, ES, Mazdaspeed, and Protege 5) does not have an inline fuel filter. The only fuel filter it has is a "strainer" or a "screen", which looks like a nylon mesh "sock". This strainer is connected to the fuel pump, located in the gas tank. Although this fuel strainer does not require periodic replacement, it is recommended that it be changed if you are replacing the fuel pump.
Jun 15, 2010 | 2001 Mazda Protege
On my 95 eagle talon the top of the radiator where the hose goes in has deteriorated. Can I just replace the top section of the radiator
If it's plastic yes, you would need to call some radiator shop's to see if they carry the tank, also you would need to have them replace it, because you need a cripping tool to replace tank and tested for leak's.
May 20, 2010 | 1995 Eagle Talon
Replace fuel filter on 2000 mazda protege
May 03, 2010 | 2000 Mazda Protege
Sugar in gas tank how do i fix this
easy, but not fun...
you need to drop the tank, flush the heck and replace the fuel pump "sock".
You might also want to consider just replacing the tank and pump while you are there....better to be safe than sorry
The good news is that the sock is what prevented some serious problems had the sugar had gotten to the engine
Apr 03, 2010 | 2004 Ford F150
Our power window gears do not work. motor works, window slips. do we change the whole motor?
Yes, change the motor out. It has a plastic/nylon bushing in it that some parts houses do sell. However, most parts stores now sell lifetime warranty motors, if youre going through the trouble of taking the motor of to replace the bushing better to replace the entire motor so if the bushing or motor goes bad you get a free replacement.
Dec 07, 2009 | 1991 Ford F150
Plastic coated sink protectors - rubber feet deteriorated
You can get a product called Plasti-Dip at your hardware store. It is the stuff used to plastc coat tools.
Mar 09, 2009 | Kohler K-8803-VS Duostrainer sink basket...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
