I already have the Samsung Soc A100 camera. I wanted to know the Minimum computer system or dvr set up requirements that it would need.I already have the Samsung Soc A100 camera. I wanted to know the Minimum computer system or dvr set up requirements that it would need.
You can't post conmments that contain an email address.
If it has audio capabilities it will have an internal pickup for the internal microphone, make sure the input is not covered or being shielded to the point it cannot clearly pickup any sound.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
