Change drum bearing on ewf1074 front loader - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Drum assy has to come out of cabnet
Posted on May 03, 2015
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Repair manual for 7kg eco wash system ewf1074?
Replacing the bearings is a comprehensive job and requires expertise and a lot of time.
First of all should estimate which parts should be replaced.
These are certainly the following parts: "Ball bearing - 25x52x15",
"Ball bearing - 30x62x16", Seal of drum shaft - 35-62 and besides them should be reviewed the state of drum shaft.
After a thorough review, you should estimate whether the repair cost or cheaper to buy a new washing machine.
First of all, I recommend that you look the tutorials on the following links:
How to Replace Washing Machine Bearings
http://www.how-to-repair.com/help/how-to-change-bearings-on-a-washing-machine-2-of-4
Dado
May 03, 2015 | Electrolux Washing Machines
On spin cycle it it has a loud noise like bearings
That will be the bearings then...
It's impossible to give you any more specific advice as you haven't stated a make and model. On some machines the drum bearings can be replaced, on many modern machines they are sealed for life and are non-replaceable and when they fail the rest of the machine is usually pretty well worn out as well.
On those domestic front loaders which can have new bearings fitted, bearing replacement is a very labour-intensive job and is often not cost effective. On commercial machines it's usually far more straightforward. on most top loaders (excluding top loading machines with a horizontal front-loader style drum), bearing replacement is relatively straightforward.
Jun 21, 2011 | Washing Machines
Inside drum of front loader loose bearing in back is ok but drum must have bushing gone how can i change this bushing the drum looks like its sealed
If the inner drum moves or is loose the the inner drum needs to be replaced .At the same time you should replace the rear of the outer drum as this contains the seal and bearings.
Nov 04, 2010 | Kenmore 43142 Front Load Washer
I want a manual for an electrolux ewf1074 front loader
http://www.electrolux.com.my/Files/Malaysia_Singapore/Manuals/FabricCare/EWF1074.pdf
Jan 03, 2010 | Electrolux Washing Machines
How do i remove and replace drub bearings
There is no no easy way to get to them, as it involves a complete strip down af washer.
Briefly, you have to remove top and front panels, disconnect all electric wiring, and remove the whole of the inside drum assy from the cabinet, then you have to split the inner drum, before you can get to the bearings, not a repair to be undertaken lightly unless you know what you are doing.
Good luck anyway.
Plz rate my comments.
Thanks.
Jan 08, 2009 | Hotpoint First Edition FEW10P Front Load...
Need to change bearing!!!
How do I change the drum bearing on a 800 electronic 9506 hotpoint front loader washing machine, please
Nov 10, 2008 | Zanussi Washing Machines
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
