Question about Garden
While pressing down the control bar to start the mower, the cable is free to move but why doesn't the end near the motor move?
What is the part on the engine where this cable attaches? I spayed WD40 but this part will not move, used last week, no problem moved some today but now stuck
  • 3 more comments
  • nomad247365
    nomad247365 May 03, 2015
    Its strange, the cable moves freely inside the cover. Whatever this cable connects to on the engine moved just fine last week, and a few times today. Have no idea what to do to get this brake lever to move. Any ideas? And thanks for the info by the way. WD was just handy, I do have plain old grease but need to find out why this brake lever wont move.
  • nomad247365
    I disassembled enough to get access to the brake lever, loosened the screw, cleaned it up, and re-assembled everything. Now the cable moves, pulls the lever but the mower is not starting. I cleaned the spark plug an cap some and going back out and trying again. Hopefully to cut grass instead of weed eating the entire yard again, did that all last summer. So now I can pull the lever back, the cable moves the lever, but the b*^#ch won't start. Tired to clean up the spark plug and cap to it, I can tell it is getting s park at least. I have dyslexia so somethings things seem backwards to me, like the cable pulling the lever.
  • Wayland Ledford
    Wayland Ledford May 04, 2015
    The top part of the mower where the brake stops the spinning motion is called the stator ring. The stator is responsible for generation the electricity to fire the spark plug as well as the timing of "when" to fire the plug. If you remove the bolt from the center of the stator ring, you will be able to see the keyway that aligns the stator ring to the shaft. These keyways are made of a soft material and often wear. This wear comes from the brake rapidly stopping the stator ring while the shaft wants to continue to spin or from hitting a root or object with the blade and rapidly stopping the shaft while the stator ring wants to continue to spin. Inertia can be troubling. Inspect the alignment of the stator ring to the shaft. If the keyway is worn and you don't see a perfect alignment of the notches on the shaft and stator ring, then replace the keyway. A simple part that can be purchased from any parts store or lawnmower repair shop for less than a buck. Once perfectly aligned, with new keyway installed, the mower should start on the first pull, something it hasn't done for you probably in ages...lol. Good luck!
  • nomad247365
    nomad247365 May 04, 2015
    Probably why my neighbor just gave me this mower a few years ago, she could not start it. I will check that tomorrow, and if the keyway by chance it the same as the ones that go in my riding mower read wheels, I may already have one, the riding mower, last time I used it would stall out when I engaged the blades, otherwise ran fine. The year before, and friend took the whole deck off so I could take that and get new blades which I could not get off. I got a new belt and when we put the deck back on, for some reason the belt was like 4 inches to big, made an adjustment so the belt would work. Undoubtedly, my friend who is a “jack of all trade, master of none, and as my daughter said, a wet match in a dark cave,, we obviously put the deck back on wrong, probably why when the blades engage it stalls right out. I stopped trying to use it when I got the push mower. Now the tires are all dry rotted and probably will need a new battery. That mower has a name, Gimme, GImme something every time you want to ride. Is from 1996, an old Murray.
  • nomad247365
    nomad247365 May 10, 2015
    The cable now moves but can't start the mower. Have to find a tool so I can get to the key way and check that. Thanks for the help. Similar problem with my weed eater, but that is now working, and with the correct oil/gas ratio, lesson learned from that one.
    New Friend:
  • 27 Answers
If the cable is not moving then it may be broken. If the lever that releases the blade brake won't move then the brake mechanism is seized and you will have to open it up and free up that mechanism. Simply spraying WD40 won't usually fix that. WD40 isn't the best solvent in this case since WD stands for Water Displacement, it was designed to keep things dry. Something like PB Blaster or Kroil is best.
Posted on May 03, 2015
Testimonial: "Here's an update ok I went outside, disassembled to where I could access this brake lever, and am now very confused. It PUSHES FORWARD, IT DOES NOT PULL BACKWARDS as the cable would move the lever. here is the link to the video I made so yo could see it. It moves one-handed. https://youtu.be/1PjJ3JY5NYY. In the video you can see me moving the cable inside the sheath quite easily. Where the cable attaches to the lever, you push it forwards, the brake comes off the flywheel?, not sure if that is what that part is called, but that opens the switch at the other end."
2011 suzuki motorcycle s40
Hi, Isaac and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2009 Suzuki Blvd S40 won start
S40 won start new battery no power anywhere after kid drained battery
Bike won start Doesn click Lights work
Suzuki LS650 Savage Boulevard S40 Motorcycle Online Manual Cyclepedia
Aug 29, 2016 | Suzuki Motorcycles
Why drive lever pushed down does not engage the front wheels of my yard machine lawn mower ?
if everything else is working fine then it has to be your drive cable or the drive motor itself. First check to see if it feels as though the cable is actually moving, slid the lever back and forth, if there is no resistance then the cable has become unattached at the lever. Next is to see if the cable is attached at the other end. you will need to follow the cable and remove the cover that to see if the cable is attached to the drive. Also, is your drive belt good? loose?
Aug 11, 2014 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Sears troubleshooting
It is likely that the pto engagement cable has broke and needs to be replaced. Lower the deck all the way down. With the engine off, kneel on the right side of the mower. look under the mower and find the end of the cable on the deck. It will be near the center rear of the deck and will have a spring on the end of the cable. Once the cable is located reach up and operate the pto lever and watch the cable. The end of the cable should move with the lever, pulling the idler pulley back and tightening the belt. If this movement does not happen replace the cable.
Jul 21, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower brake cable
unhook both ends lubricate it and work it back and forth by hand
if it doesnt free up replace it
Jun 13, 2013 | Garden
How to take up slack on mower throttle cable
My first question is why is there slack in the cable? If it's just the outer housing is drooping away from the handle where it runs down to the engine, you can use some plastic wire ties, or electrical tape, or for a short term fix, even twist ties (like for bread sacks).
The outer part of the cable should be clamped down near the throttle control. Loosening the clamp and moving the outer housing back towards the handle will take up looseness in the inner cable.
If it's a new cable, you may need to pull the interior cable out at the engine end and shorten it by cutting with pliers. Most cables have a solid wire in the center. The cable fits into a small hole on the throttle arm. There should be an "L" shape on the end of the wire--if you cut it off, make sure to leave enough room to make another the L-shape in the end of the wire--it's what keeps the cable from sliding around in the hole.
Jun 25, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
I have a 1988 Model 26624, 21" Key-Lectric mower. I've noticed over a period of time that the mower blade slows considerably when cutting the lawn. At first, I thought it may be grass accumulation under...
Yes, it sounds like you need to adjust the blade brake clutch (BBC). I have a PDF service manual that explains it. If you post your email address I can upload it to you. Here's an excerpt from the manual:
BBC
BBC Adjusting the Blade Brake
1. Stop the engine. Pull the wire off the spark plug.
2. Remove the two screws securing the screen
panel to the top of the mower housing as shown
in Figure 22. Remove the panel. (The panel they're
referring to is the red screen between the motor
and handle.)
3. Move the control bar down and lift up against the
handle. With the control bar against the handle,
measure the spring length (L) at the front of the
spring as shown in Figure 26.
4. If the spring dimension is greater than 32 mm
(1-1/4") an adjustment is needed.
5. To adjust, loosen the bottom jam nut on the blade
brake cable as shown in Figure 27. Adjust the top
jam nut until spring dimension is as near as
possible to nut; not less than 25 mm (1") See
note below.
NOTE: Adjusting the top jam nut too high can
cause the cable end to crush the plastic fitting
when the control bar is moved up against the
handle. If the spring cannot be adjusted to less
than 32 mm (1-1/4") before the cable end
contacts the plastic fitting, the clutch belt is worn
out and should be replaced. After replacing the
belt, adjust the cable per the above procedure.
NOTE: 1990 and newer models are equipped
with finger tip adjusters that do not require tools.
Use the same adjustment criteria on these
cables.
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
My craftsman lawn mover (675 series) won't stop once the control bar is released. what's the problem?
IS the Control Bar releasing all the way? Look down by the engine and you will notice a small plastic tab with a wire inserted. When released the lower end of the control bar must touch or move linkage to touch this tab (which is connected to the Magneto Wire) to stop the Mower. I think you are just a little out of adjustment.
Sep 12, 2009 | Craftsman Garden
Pull bar is not pulling cable back far enough to start. How do i fix this?
Make sure cable sheath is securely mounted at both ends and sheath is not moving, just the cable.
Jul 31, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
How to ajusta throttle linkage on riding lawnmower
Near the throttle control assy on the engine the cable has 1 clamp on it. It should be very near the end of the cable shielding. Losen the clamp and move the throttle control until the cable EXTENDS out of the shielding and re-tighten the cable clamp. You may have to do the trial and error on the adjustment but usually is should not have to be moved more than 1/4 inch from the original position unless the cable clamp over the shielding was loose to begin with.
Kelly
Jun 03, 2009 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
189 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
