Question about Singer Sewing Machines
I have a singer one plus. It will not go more than 5-10 stitches without an alarm going off that my top thread is broken. However the thread is fine! Is there a bad sensor?
    Top Expert:
  • Singer Master
  • 44,352 Answers
Probably. Have a service done on the machine to rectify the fault.
Posted on May 03, 2015
SOURCE: thread on bottom, bobbin thread loose
Sounds as though you've misthreaded the upper tension. The best way to verify this would be to thread your machine, lower the presser foot on to the material. Now try pulling the thread through the needle. (Assuming your upper tension dial is set to a number greater than one). You should feel resistance. Should you not feel resistance, rethread your upper tension.
Posted on Feb 01, 2008
  • 192 Answers
SOURCE: Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Posted on Apr 08, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: I have a Singer 4832 c. I can't find my manual.
check to see if your needle is bent
check your tension
if you need a manual go to diplodocs.com
in the center on the page select brand-
your is there under singer
then product look up model number
manuals are pdf & free
Posted on Aug 05, 2010
RichSew
  • 184 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Help re. error msg C6. Manual says my top thread is broken but mine isn't.
could be a problem with the sensor giving the wrong signal, the sensor may have to be checked
Oct 01, 2015 | Singer One Plus Computerized Sewing...
How do I fix my singer.
the problem most likely is thread tension possibly on the upper thread
It is not pulling the thread up from the bottom allowing the bottom thread to become tangled
Apr 30, 2015 | Singer Sewing Machines
Singer 2112
first ,re thread the upper bobbin, check the needle to match the fabric and the lower bobbin thread should be the same like the upper thread. If it dose not work, clean the discs tension for the upper thread.
Aug 15, 2014 | Singer Sewing Machines
Singer 4411 sews fine forward and reverse in straight stitch, in zigzag top thread looks fine on top, but all loopy underneath and will only reverse stitch 1 or 2 zigs or zags
check that the bobbin underneath has the same thread as the upper bobbin and that you push all the way on the lever when sewing back and also, go full speed as this happened to me and that was my mistake. Hope this will help you :)
Aug 11, 2014 | Singer 4411 Sewing Machine
How hat do to adjust the tension on my Singer 3201 - the under thread is real loose
If the bottom stitches are messy it usually means the top thread isn't threaded correctly.
May 10, 2014 | Singer Sewing Machines
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Machine will stitch for a few stitches and then stop and beep.
Your problem is most likely that you've run out of bobbin thread (or about to and the bobbin thread is now loose around the bobbin), your top thread is broken/about to break, or you have a birds' nest (a messy knot of thread) forming underneath the fabric/presser foot and/or within the feed dog. Upon occasion, it's a false alarm. Remove the fabric from the machine and clip your threads. If your bobbin and top thread are fine, place your fabric back in and start sewing again. If you get the stop and beep again and the threads remain unbroken, try rethreading both the top thread and the bobbin. Should you still get the alarm, hit the button to start and see if it resolves itself after a couple of tries. If it doesn't, afraid you have a problem I haven't encountered yet. But so far, the above steps have always resolved the problem for me in the last 6 years.
Mar 04, 2011 | Singer CE-100 Futura Computerized Sewing...
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
43 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
