Question about Bosch Water Heaters
We have a gas unit in our ensuite for a hot water we can not seem to get any hot water the gas cylinders are getting low so i have asked for them to be refilled or could i there.
No hot water the gas bottles are running low
    Top Expert:
  • Bosch Master
  • 42,218 Answers
Refill the gas bottles and then if that doesn't fix it, get a technician out as it may be the pressure switch not opening the gas so that the pilot light ignites the burner
Posted on May 03, 2015
Unit lights up from flame but seems to have a low gas flow so water does not get hot
could be a faulty regulator or blocked supply line
get an accredited gas fitter to check out the problem
Oct 16, 2015 | Water Water Heaters
Rheem water heater about 3 years old. No hot water.
Get more fresh air to unit and see if that improves problem
Bad gas control valve
Low gas pressure
Bad vent
Lack of maintenance/ dirty combustion parts
Low amount of fresh air/ dirty air intake/ flame arrestor screen
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Rheem will tell you to call service technician
Gene
Oct 20, 2014 | Water Heaters
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add a comment as needed
Jun 02, 2013 | Water Heaters
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Noritz tankless gas water heater. Hot water pressure is low. Unit does not "click" on when hot water is opened. No hot water.
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
Feb 02, 2011 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Rinnai XR 20 - water temperature varies hot - cold - hot etc during 4 to 5 min shower
your gas supply may be to low to keep the unit firing while you are showering...especially if you have other gas appliances running while you are using the unit.
If this is happening after someone else has recently used the unit....then it may be a problem that some call stacking. The unit works on flow....not sure about that unit but they usually take between 1/2 - 3/4 gallon to turn the burner on. If someone recently used it and then you get in the shower...you will get the hot that is already in the line but then it takes that initial amount to fire again, thus loading the pipe with cold water.....it then comes out on you followed by the hot that has finally entered the line. Once it is past that point there should be no issue, unless it it a gas problem like I mentioned.
Oct 24, 2009 | Rinnai Water Heaters
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Feb 17, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water Heaters Logo
78 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
