Question about INTEX Sand Filter Pump
When I turn on filter it has lots of pressure and suction but after a few minutes it goes down, I turn it off and back on and it shots high pressure and suction for another few minutes
  • 2,760 Answers
This is most sure a sign of a restriction in your suction system , id bet someplace around the strainer if I was to bet
Posted on Jun 26, 2015
  • billy graham
    billy graham Jul 05, 2016
    you might think but when I use the recirculate function in pushes fine. there is also plenty of suction at both inlets.
What is white round item that I suctioned out of plumbing?
How to Reduce High Pressure in Your Pool System ...
www.inyopools.com > How To Guides
Or every time you turn the pump off, the back pressure is so high that it blows the cover off ... One filter manufacture has suggested putting DE material into the creases of the pleats to ... high spa pressure - If your system had been working in either spa or pool mode, .... The filter seems to operate under too much pressure.
Troubleshooting pumps - Mc Nally Institute
Dec 28, 2015 | Pool & Spa
Temperature gauge goes up then down engine
Sounds like the thermostat is sticking, on warm up on lot of vehicle the gauge goes past normal and when the thermostat opens drops back. If it is going higher than normal, the thermostat is opening late. Needs changing before it stops opening altogether.
Jan 07, 2014 | 1996 Lincoln Mark VIII
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
How to tell if you have a bad suction valve for ac compressor?
Hey there. First question I have is if you have a heat pump or straight ac. Straight ac is easy to diagnose. Your suction pressure will be high, your head pressure will be lower, not sure how clean your condenser coils are so its hard to say how high. Your amp draw on your compressor will be lower than normal. Also, when looking at the suction pressures, you have to keep in mind what temp the air hitting the evap coil is. If it is warm, that will make your suction pressure go up. Another way to check the vavles is to hold the suction line at the compressor when you shut it off. If the temp goes up the second you shut it off, this tells you the hot gas is leaking through your suction valves. You can also try to pump the system down, then shut it off and see how fast the pressure builds back up, this will give you and idea how fast it is leaking through. Let me know if you need any thing else, I'll be here.
seth
Jun 26, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Cannot remove water filter from LG 26 cu ft side-by-side in the d
Here's the only thing that worked for me in getting the water filter out of my LG refrigerator after trying for three weeks, pulling hard by hand, using high-grip gloves, and trying an oil filter wrench. You have to break or lessen the suction created by the water in the filter. Do this by first turning the filter to the Removal position (in my case, a quarter-turn to the left). Then grip the filter tight and rock it back and forth slowly as far toward the back and front of the refrigerator as possible, while keeping a bit of downward pressure on the filter. This lets the two O-Rings "walk" their way down the insert tube. After only a few pushes and pulls - voila! -- it lets go and will drop right out.
Nov 24, 2008 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Extremely high head and suction pressures
disconnect the blower and turn on the ac.see if the coil frosts evenly.when you had the system open,you should have changed the liquid line drier.
Jul 29, 2008 | Heating & Cooling
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
INTEX Sand Filter Pump Logo
1,067 people viewed this question
Top Intex Garden Experts
J.D. Browning
J.D. Browning
john h
manhal kurdi
Are you an Intex Garden Expert? Answer questions, earn points and help others
