Question about Electric Health & Beauty
Where would I get a charger for the Mickey Mouska space electric scooter.
  • 2,963 Answers
Try MFG website or eBay
Posted on May 03, 2015
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Need a battery charger for rascal 600t
I recommend the 5 amp Charger. Monster Scooter Parts have them.
Apr 09, 2014 | Electric Mobility Power Electric Scooter...
Convert off board battery charger to work on rascal scooter
It has been done before, but you will violate the safety to do that and anything that happens with this scooter will be your fault! You will need a female electrical part for an XLR Plug to make it so the Male end from the charger will plug in. after wiring the Female connector and plugging the charger in the scooter will run while the charger is plugged in. This can cause safety problems.
Apr 03, 2014 | Electric Mobility Health & Beauty
Hi do you need to turn on key to charge up battery on a wheeltech mobility scooter i just purchased with no manual thanks
No, you don't need to turn on the key to charge. Just plug in the charger and turn on the charger if there is an on/off switch on it. The charger indicator and the scooter meter will read full when the scooter is fully charged. Hope this helps.
Mar 02, 2011 | Electric Mobility 4 Wheel Power Electric...
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
Electric scooter problem
Yes, you will need to get a charger based on the number of 12 volt batteries in the Scooter. I recommend TNC SCOOTERS to buy the chargers. Very good service and lower than most prices.
Dec 17, 2008 | Electric Currie EZIP 500 Scooter
Health & Beauty Logo
74 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
